>Even with the title this is still On Topic, sort of. With my shop in the basement, the on topic part, I can`t hear our door bell. Any ideas how I can remedy that. My thought is to use a relay coil. But I looked at the transformer and it was a 16 volt. I have my doughts of finding a 16 volt coil. Any other Ideas. Larry in Ohio TIA
>There are wireless door bells available from many hardware sources - maybe even the borgs. Just a sending unit (the outside button) and a receiver (the bell). They make them with multiple bells so you can have one upstairs and one down in the studio. I put one in at work for shipping and receiving, and it took maybe 10 minutes.
I just did this this past summer myself. I did not want to be changing batteries all the time with the wireless units, so I installed a higher amperage transformer, then duplicated (hooked the three wires to the system where they fed the old chime) the three wires which ran from the existing chime to a new chime downstairs, instant dual chimes for the door bell. You must upgrade to a higher amperage, not a higher voltage, the amps are what make the chimes chime.
>When I look at my transformer I just have 2 wires from the original doorbell connected to the terminal.(comes thru the wall and I can't run wiring from the 1st chime)
If I connect the new doorbell wires to the transformer I'll just be supplying power to it. I'm a bit lost here.
>You can't hook it up just from the transformer. It will just supply power as you said. Those wires go to the first bell, then have a link to the button on the door. If you cannot get wires from the original bell, then the best alternative is probably one of the wireless ones that some have mentioned.
