Bending Crown Molding
Wayne
>A lady wants me to make her a mantle out of red oak. She would like to have a 12" radius on each end. The mantle projects out 12". Is it possible to bend a radius with 3" red oak crown molding. If so does it have to be steamed??
Re: Bending Crown Molding
Keith Newton------WebKitFormBoundaryDZmgloT+ZiYFgX
>No, Bending wood requires compression straps from end to end, so that none of the cells are being stretched, and all are in compression. For things like molding, it will always flip to the flattest easiest bending plane, which would be flat across the back.
It is best to plan to build up solid wood, then mill the pattern in the solid stock. That is not to say, that you can't bend a large square, then mill the pattern, but bending large parts is very difficult.
Jason Roehl in Lafayette, IN
Another option...
>...is to take two pieces of the molding and rip them into thin strips that are the width of the saw blade you use--what becomes sawdust in one piece is a saved strip in the other. Then you merge the two back into a whole. You may still need to steam-bend them or at the very least, get them wet, depending on the wood and curve radius.
Jason
Re: Another option...
mwwoodworks
>JUST SAY NO! LOL It's not worth what you are going to have to go thru to get that job done! I just recently had someone order arched crown for a special set of cabinets. I told them that I couldn't make the moulding. They spent over $300 for one piece of crown. Needless to say, when I told them that it can only go across the front and not down the sides they were a bit upset. There is no way to match the profiled angles of the arched crown to the angles of the straight pieces going down the sides! (Not the look they were wanting)
The whole point being sometimes people ask for things that are d*mn near impossible. They don't know that it can't be done, they need for you to tell them that either it isn't physically possable or that what it would take to get some of these things done would have such an unrealistic pricetag they would have to send your kids to Harvard. LOL
You can order arched crown but it os very expensive! This piece that was ordered was built up, cut to the matching angle of the arch and then milled to the shape of the crown.
Go luck!
try bendywood *LINK*
Robin Corell in Atascadero Ca
>I suspect that Bendywood will not want to bend on a bias but if there is any way to do it I suspect that it would be with this stuff.
Robin
bendywood
possible way
Dan Donaldson
>I am not sure you could get the grain to work out, but you might be able to find someone with a big lathe, take a 24" disk if wood thick enough and turn the profile on the edge of it then cut it to fit on the ends of the mantle. I did something like that (a lot smaller and without the grain issues) for a friend of mine. He had some oak floor molding about 4" high that he wanted to bring to the end of the wall then around the bullnose on some stairs. I made up a couple of disks, cut them in half and glued in a sliver of the molding which I colored black on the edge with a pencil. I turned the profile into the disk, using the dark molding sliver to get the profile correct, drilled a hole in the center to go around the bullnose then cut it in half. When we put it on the wall, it matched the profile of the molding and wrapped right around the stair. Looks almost like it was designed that way. ;-)
Might not be practical for something that big, and the grain matching with the end grain might be an issue, but it might be something to think about.
