Re: Tool Life Expectency
JohnKJordan in East TN
>>...max life expectancy that I should be
>able to get out of a particular tool
Yikes, that that sounds incredibly difficult! A good hand tool could last for generations. A cheap cordless drill will probably not.
I think the maximum life would depend on factors such as the type, quality, use, and care of the tool, and how much rebuilding is planned.
For tools that need regular sharpening, such as a bowl gouge for a lathe, I suspect you could measure the minimum metal removed for each sharpening, and calculate the number of sharpenings before you judge the tool too short to use. For a power tool, I think you'd have to decide whether the maximum life included replacing bearings and replacing or rebuilding the motor.
I think I'd just make some guesses. One idea - when my job required extimating things, I ususally provided a range instead of a fixed number.
