Sawdust and planer chips
David
>Disclaimer: Now I realize that some folks believe that there's no such thing as a stupid question. This one, however, has the potential for being at the bottom of the question food chain.
Does anyone have a good use for sawdust and planer/jointer chips?
I typically dump my tailings on the compost pile but given our knee deep snow, that isn't going to happen. I know about using sawdust for added traction on ice, and using chips for burnishing your work on a lathe. I've also followed the Furniture Guys' practice of using planer chips to scrub of stripper but frankly, I don't have any refinishing projects in the near future and many bags of sawdust/chips awaiting a proper end.
Sorry if this is too goofy, but any suggestions (well, maybe any) will be seriously considered. Maybe ebay...
Thanks!
Re: Sawdust and planer chips
Carol - now in NC Nebraska
>Well if this works, maybe you could replace "snowmen" with "cabinets" and draw a more appropriate picture, maybe you could solve your problem and make a buck or two.
mdclor
>Save until Spring, about June in your area :^), then use as mulch for flower beds. If you weed first and put down a 3-4 inch thick layer on top of newspaper, you will probably not need to do much more weeding during the remainder of the season. I think it is a nitrogen depleter so be certain to put a good coat of time release fertilizer, such as Osmokote, down under the newspaper.
HTH,
Merle
Jay St. Peter - SoMD
>Won't help you, but I've got a friend who has been clearing scrub from his land over the last few years. I call him the "anti-pyro" because he can never get his burn pile to burn. So, I give him my chips and Christmas trees as kindling. Otherwise, I used to dump it in the woods depending on what I was working with at the time. Too much MDF and it goes to the dump.
Jay
JohnKJordan in East TN
>Some other ideas: offer them to a local university or art school where they are highly prized for the raku pottery process. A potter friend used to get a large bag from a cabinet shop every few days.
Farms are always in need of bedding for horses and other animals (as long as there is no black walnut which is dangerous to animals).
Mix with hot wax and make fire starters for fellow cold people (could be profitable if you make enough).
Gene Gauss
>In the spring, summer, or fall, I broadcast spread it on my lawns. In the winter if the snow is too deep to negotiate, I wait for a windy day and toss shovelfuls into the air at a time and let the wind spread it across the lawn. Come spring, it kind of settles into the lawns and disappears as more organic material in the topsoil. If you're in Utica, you've probably got a little more than here, just west of Schenectady.
McKay
>I wanted to re-cycle the schools large amount of sawdust and a local horseman wanted to get it from me. I checked with a large animal vet. and he said that the walnut dust in smaller quantities would not harm the animals. I guess that unless you are working exclusively in walnut it would be ok.
David
>Most of the sawdust I'm "making" right now is pine from a post and beam barn, a.k.a. my soon to be new workshop (sorry for the gloat) that I'm finishing up. Planer chips are sugar maple.
When there's snow on the ground, I've tried the broadcast method and used to put my ashes on a piece of land that I plow up for a garden every year--until the dogs decided that snow with stuff on it was better to roll in than plain old white snow :(
I've wondered about making fire starters. Will have to play with that next! Should also check with my friends with horses, goats, etc. about bedding. Or perhaps along the lines Carol suggested, free deconstructed furniture.
Ice de-slipper
Al Goldstein
>I have water runoff in two places on the sidewalk in front of my house. In the winter two very slippery ice sheets form in these places. I keep a barrel of sawdust in my garage and use a gallon plastic milk jug with the top sawn off as a scoop.
When the ice forms I spread the sawdust out on it. This not only warns my neighbors, but takes all of the slip out of the ice. They can safely walk on it without fear of falling. During a thaw some of the sawdust may get tracked into a house - but nobody has ever complained to me.
Al
Pete in Holland, MI
>During the cool/cold months (when people's windows are closed), mine go in the backyard fire pit after dark. Light them with a match. They don't burn well, but a couple bushels will smolder all night long and be gone in the morning.
Wood scraps are cut up to small pieces, boxed up, and brought to work where several folks snatch them up for kindling.
For me, it doesn't make much economic sense to burn a gallon or two of gas to deliver/pick up a couple bags of chips to anyone.
Don't do too much woodworking in the summer, so chips are not a big problem. If I do though, I burn them in my steam engine (Summer passion).
Sawdust is great as a mulch and you realy don't
henthorn
>have to worry much about oxygen depletion UNLESS YOU WORK IT INTO THE SOIL. Just leave it top side and let the sun, rain and wind work on it and it will be fine as it gradually decomposes and enriches the soil.
Re: Sawdust is great as a mulch and you realy don'
David
>I would hesitate to use a thick layer of sawdust as mulch since my outdoor piles tend to form a tough crust. My usual routine is to let the piles sit for about a month, then work it into the soil.
I've been boxing scraps for years to burn. Now that we have two woodstoves going, and soon a third in the barn/shop I only fear a scrap wood shortage.
Based on earlier suggestions, I now have a neighbor who'll take the chips and some sawdust for bedding (he has goats).
Re: NO Walnut in Bedding!!!!
Brian in Brighton
>I have heard from many sources that there is something in Walnut that will KILL animals bedded in it. It causes respiratory failure.
So DO NOT use it for bedding. I would not use it for mulching into anything that is for eating either. Flower gardens good, veggie gardens bad.
Brian in Brighton
Uszed it for years in my garden and it worked
henthorn
>great. Too much hysteria about its dangers. It isn't the small amount of toxin in the wood that causes problems in gardens. It is the toxins that come from the roots of walnut trees that grow near gardens that cause problems. Even then they only cause problems for certain plants.
Re: I have used walnut shavings
Larry Clinton At Frankfort (Central)., Indiana
>extensively in my yard and tomato garden. The ONLY place I have ever heard of walnut causing a problem is HORSE BEDDING. Horses are extremely sensitive to it and have an allergic reaction. Of course several plants eaten by other ruminants will kill horses. Cattle, deer and other animals can eat many things without harm that will kill horses. Common hay which becomes just slightly moldy will kill horses - Ok for cattle.
CHARLES EVERLY
>I GIVE MY SAWDUST AND SHAVINGS TO LOCAL AUTO REPAIR SHOPS. THEY WORK BETTER FOR SOAKING UP SPILLED ANTI FREEZE THEN OIL DRY
CHARLES EVERLY
>I GIVE MY SAWDUST AND CHIPS TO LOCAL AUTO REPAIR SHOPS. THEY WORK BETTER FOR SOAKING UP SPILLED ANTI FREEZE THEN OIL DRY
Charlie in Russellvlle, AR
>There are oil etc. spills that need cleaned up, or how pellets for wood stoves?
Kenneth Mc Cutchen
>with the melting snow and salt on the garage floor in the winter using planer the sawdust soaks up the water and salt and is easy to clean up when it is dry
leo
>Bag it and give it to farmers.they use it for bedding. and most would appreciate it.
David
>Well, the first two bags of jointer chips and sawdust were put to use today! Oil truck came early and could barely make it up the driveway with the ice that had formed overnight. Worked beautifully.
Actually, these are the third and fourth bags, a friend took some maple chips for his goats to use as bedding.
Jeff Mathewson
>Many years ago there was a TV show featuring two guys that refinished furniture. After applying a stripper, they would use a handfull of router shavings to remove the finish. I tried it once on an oak curio cabinet I purchased in the damaged furniture area of local furniture store and repaired. It had a fau paux finish on it of somekind and when I tried to strip it with pads, it just smeared and filled the pads. I tried the router shavings and it worked terrific As you spread the shavings, they would drop off leaving clean chips to work with. Soft enough as not to mar the work plus worked well in grooves.
