I almost couldn't help laughing.......
>My friend bought a compressor with spray paint kit. He said it did not come with instructions. (Or could it be that he did not read them?) He made sure the compressor would go to 110 or 120 PSI to run the nails guns he also bought. After a while, he got out the paint gun and hooked it up for the first time. It made a "little pop noise" (he's hard of hearing, so it may have been a big pop noise) and the bottom of the cup was no longer concave. It's convex and you can't sit the gun down. He fixed it with a hammer. His comment was "who knew you were only supposed to use 20 or 30 PSI, not 120." He actually called me and asked and when I said about 30 psi he said, "yeah, you are right."
Re: I almost couldn't help laughing.......
My name is Steve and I'm not a manly man . . .
steve mackay
>or so the television would have me belive. Learned long ago to, at least, sniff the directions / instructions. Since then I spend less time in the ER.( I used to be a regular )I stop and ask directions no more than two or three blocks into unknown territory.
>That sounds just like something I would do. If a little is good a lot is better. Hey Bubba watch this.
should have bought the Binford Spray-O-Matic 5000
Robin Corell in Atascadero Ca
Bill Hammond, Oregon Coast
>I always read the instructions, usually after to see what went wrong. If you leave them in the bathroom you can peruse them while waiting to see how much blood the band aid will hold back.
Re: I almost couldn't help laughing.......Long
Tom MacGregor
>Then there was the time about 35 years ago in my first house that I figured I didn't need instructions to put up sheetrock for the first time. After all, I'd taken Architectural Drafting in High School, so I already knew a lot about carpentry. Got the stuff home, set a sheet on the sawhorses, measured out my first cut & grabbed my new Sears Skilsaw. Made it about 18 inches before I started to think there had to be a better way to cut that stuff. Showered, changed into some clothes that didn't leave a trail of white dust & went to the neighborhood hardware store to christen my new account. Had about $30 in my pocket hoping for the best. Not wanting to admit my ignorance, I walked in & said to the owner, "Can't hang much 'rock with nothing to cut it with - figured you could fix me right up!" He handed me a utility knife. Hot Damn! A buck ninety-nine! Boy did I just get off easy! Took it home, looked at the rest of my pencil line, set the point at the end of my saw kerf and (expecting to go over it several times to sever the piece) scored it for everything I was worth. Just as I was about to draw across pass #2 there was a sharp crack. Looking in amazement at the neatly broken piece of sheetrock I suddenly understood how it was done.
Randy Johnson Connersville, IN
>Add me to the "ain't that the way it's done?" list. Instructions are for when assumptions don't pan out.
I'm a little bothered that all respondents so far are male. Surely one (or two) of the ladies who come here regularly have had a little egg on their face at least a few times.
Stuart Hough
>Dad always told me..."better to have a screw or two left over than finish and be short one"?!?!?!?
Cody Lewis in LV
>I just have to say I love all you guys. I had a tough day, but I'm still laughing over these comments. The story about the drywall is just as good as the sprayer story. Thanks.
Sure am glad.......
>..... to hear I'm not the only one who did that.
But I didn't hammer the bottom, just left it round like that.
Happy Woodworking!
childhood memories
>My parents left the Amish church when I was about 2 years old and joined a church that drove cars but they were all supposed to be black cars. Making a car black is easy. It doesn't have to be pretty. So of course one of the first tools I remember watching my dad have fun with is the paint sprayer. A real air compressor would have been too easy, and expensive. What you did is find a reject pump somewhere cheap and attach it to a piece of wood. An old water tank holds the air. There is no need for a safety valve; you just make sure the tank is never over filled. An old gasoline engine that will take a few hours to get started finishes the outfit. Or course there is no pressure control on this outfit; you simply hold the engine tight until you have enough air to spray for a bit then move the engine a bit so there is slack in the belt. Of course the spray gun had a round bottom; what's wrong with that? ;) Ever day I wonder that we made it through childhood alive. Our cribs were covered in lead based paint. Now that I think about it, that explains a lot.
"What's wrong with that?" Foxworthy voice
>The phrase "What's wrong with that?" should be said in the Jeff Foxworthy tone of voice that is heard on his "12 Days of Christmas" song.
Re: childhood memories
Randy Johnson Connersville IN
>That sounds a lot like a segment of Handyman's Corner on the Red Green Show
Nathan
>So far my best feat occurred while drilling a small hole in a steel profile with an electric-powered hand drill. The drilling wasn't going so well and I figured the drill bit was dull, so I pressed harder and harder and then added more RPMs. Finally, after what seemed like forever, I broke through the very thin profile. I pulled the drill bit out and could feel the heat. I looked closer and, to my surprise, I see that the flutes have been twisted out so they're almost straight! I had the drill running backwards...
I have that drill bit on display above my bench.
>Hope you didn't live in Connecticut then.... I was helping a friend do his basement and the next door neighborer asked how to cut sheetrock, Skil saw I replied, and then forgot about it. Must have been a few months later my friend was telling me about his stupid neighborer, seems he borrowed my friends Skil saw and...
I never did tell him.
Bill
