>my wifes washing machine is leaking water it is an older maytag I checked the hoses it is not them I did not notice it with cold water but with the hot I see it puddeling feom the back of the machine. any ideas as to if it is user fixable or if I need to get an expert of god help me not. Buy a new machine? any ideas where to look?
Re: I think it is the hose from the valve to the t
John Veerkamp
>Ernie,
on the maytag we had the top was opened by pushing in on the body just below the top and pushing up on the top at the same time. It kinda hinges on tabe in the back. The hose isn't too difficult to replace if you can find one the right size. Washer Equipment Co in KC used to mail parts. They are located about 17th and Main.
>found it two screws on the bottom front then two up under the top at the front it hinges back and the part is a filter I think? it is missing the top and it is clogged enough to let the water caise and leak out
there is a parts shop half a block from work I will be there on morning break
>Ernie I think what you see is what they called a "water dam" IIRC. I replaced three in our old Maytags. Also the top is suppose to be missing. It`s suppose keep the water from backing up into the city supply. I never really understood it. Larry in Ohio
We had a similar problem on our older Maytag also. A Maytag repair guy walked me through the problem over the phone and saved me big bucks on a service call. I'll bet it was the same as yours, since he said it is the single most frequent repair on leaking Maytags of older vintage.
After you lift the top, you will see your filler hose on the left. In this hose line you will see a plastic "coupler" for lack of a better word. The fitting will be screwed to the machine with one screw. It's intended purpose is to swirl water as it comes through the delivery line. I'm betting your leak will be there.
The Maytag guy said he could sell me the replacement part, but did not recommend the expense. He said they almost never bother replacing it because it really doesn't do much of anything. Instead, he had me go to the local hardware and buy a simple plastic coupler (sorry, forget the exact size...take your old one off and take it in for sizing). Buy a couple of small screw clamps also, since the clips you take off will likely be ruined when you take them off.
After the coupler is in, I would suggest wrapping the assembly in some sort of protective padding since the assembly you removed also kept the hose from rubbing against metal and wearing through. I just used some old towel strips wrapped around the hose and held with black tape.
Anyhow, if this is your problem, and I'll bet it is, this fix costs all of $2, including clamps. Hope this helps.
