Snaplock Dust Collection pipe *LINK*
Peter Gregory
>I'm assembling my dust collection pipe and finally figured out what "snaplock" pipe is and thought I would share. Snaplock ships as an almost flat piece of metal, with a system to hook together at the edge. Turns out, it is pretty time consuming to snap it together.
The big trick I have to share is to vice grip the first corner together and use a clamp to make the seam line up, all the way down the pipe. Then you just muscle it together. I can't do it with gloves on, I need to the friction to make the pipe move.
If I had know what a PIA getting the pipe together was going to be, I would have bought spiral instead.
It is a dust collection Christmas.
http://store.oneida-air.com/sub-category.asp?cID=135&mID=-1
Re: Snaplock Dust Collection pipe *LINK*
Larry in NW Ohio
>Peter That is one big reason I used S&D sewer pipe to do my system. I would never use metal myself, it`s just to hard to work with. Found that out when I worked with it when I was employed. We use to cuss at that stuff whenever we had to work on it. The bad thing bad about S&D is that it only comes in even sizes. But I can live with that. Good luck with your system. What kind of DC did you get? Larry in Ohio
Rob Stokes in North Vancouver
>Make sure you seal the length of the seam (each seam) with foil tape (connections too). Snaplock is also notorious for not being airtight.
Rob
Re: 2 replies in one - thanks for the suggestions
Peter Gregory
>I got a 3hp Dust Gorilla.
I'm aware I have to seal everything, 20% leakage is a minimum with pipes like this.
I'm stocked with metal jig saw blades, I'm cutting pipe today!
Thanks for the suggestions.
Murph
>Peter or anyone for that matter,
Let me know if you need more 7" Snaplock as I have 4 60" sections I didn't use that I'm looking to sell. You'll love the Dust Gorilla! I just installed my 2hp and it works like a charm. Email me if you're interested and I'll sell em to you at a resonable price.
Murph
7" Pipe
>This sounds like heavy duty ducts to me. You can cut it easily with aviators snips. Cut it to lenghth before you assemble it or you can get a set of duct shears that will cut it easiy after it is snapped together.
To snap it together, put it down on the floor and kneel on it with one knee on each side. Use your knees to hold it together and your thumbs to press the seams together.
