zero clearance throat plate
Woody Rhinehart
>I have an old sears table saw which has a 3/32" thick throat plate. What did people do for zero clearance plates?
Woody Rhinehart
Crude approach/elegant approach
Rod Peterson -- Ormond Beach
>I had a Sears Model 100 table saw for several years, and probably had essentially the same circumstances as you. My first solution was to use a piece of 1⁄8" Baltic birch plywood, which, while it made a dandy insert and served much of the purpose, was still a fraction lower than the table, and thus, was occasionally not satisfactory (such as when you need close-to-the-blade support at table top level). That was the crude approach.
After a while, I got a little more serious about it and fashioned a plate from ½" stock as described in the article on the subject at my website. It involves routing relief areas out of the plywood to accommodate the support shelf within the throat of the saw and which dictates the thickness of that part of the insert.
I was able to get a much stiffer insert, which was level with the surrounding cast iron. Unfortunately, although I was able to duplicate the effort when I wore out the insert, it was really a kludge affair between getting the right thickness for relief and fully relieving the areas in the insert to fit the irregularly shaped shelf material in the saw throat.
I'm sorry to say that the best solution is what I did—I adopted a Unisaw. See my replaceable insert insert article here at WoodCentral. I realize that's neither quick nor necessarily practicable. I just wanted to show off both my Unisaw and the article.
Rod
Re: Crude approach/elegant approach
Ken Oakley-Sunny St. Cloud, Fla.
>I had the same Craftsman saw and I made zero clearance inserts using Plexiglas. After a while I forgot where I put the original insert because I used only the Plexi inserts I made. I did that for 30+ years until I too adopted a Unisaw. A quick one time solution is to obtain some very thin,.030 or less, plastic, double face tape it on the metal insert, lock fence on top of the insert to hold it down while you raise running blade slowly through it. When finished just peel plastic off insert.
Re: zero clearance throat plate
Joanne Adler in Pt. Pleasant, PA
>I've used hardwood scraps, and more recently, mdf. It's pretty cheap, cuts and sands to fit easily and even planes to the correct thickness. I don't need to spend too much time and can have several for varying blades, dados, and angles for very little money.
Robin Corell in Atascadero Ca
>I make my inserts a bit thinner than the recess and then drill and tap some holes over the cast tabs. I use the same drill and tap used for metal and reinforce the threads with CA glue. I saturate the threads compleately and let the glue dry for an hour or two then run the tap through a second time. I use allen head set screws and have had excelent results.
Robin
Edward in Vancouver
>There are many ways, I like to use hardwood flooring samples, and "build up" the thickness with masking tape underneath the insert so it's flush with the tabletop. Another cheap and nasty way is to stick a piece of masking tape over the factory insert's slot, fill up the slot with bondo, and when it cures, remove the tape.
Zero clearance throat plate for Sears
Lee Schierer - McKean, PA
>My Sear throat plate measures .132 thick (a little more that 3/32"). I use Luan underlayment plywood for inserts. Because it isn't stiff enough on its own, I glue a piece of 3/4" stock to the underside where it will clear the blade and the blade washer. Use the old plate as a template.
Lee
Re: Zero clearance throat plate for Sears
Woody Rhinehart
>Thanks! One comment:the .093" plate is 2.4" longer than the thru hole in the casting.
Another way
>If the saw came with a dado insert you can fashion a wooden insert for the dado opening and attach it to the throat plate with scews up from the bottom. The wood piece would serve as your ZCI and would be replaceable. Sort of like the inserts with the removable wood strip only in your case it wouldn't slide out. Make the insert 3/8 thick and remove enough material from the top to fit in the cut out on the dado plate leavinmg about 1/4" below the metal plate. Countersink a couple of holes on the bottom through the wood and then drill and tap the metal insert.
Lee
