A55 Smoothing Plane
Ellis, one more messageboard suggestion
Andrew F in Australia
>HI Ellis,
I don't know if this has been mentioned before, or if it's feasible, but is it possible to anchor the left frame of the webpage so that, when you scroll to the bottom of the message list, it is still possible to get to the links to another forum/etc...
At the moment, if you're at the bottom of the page, you have to scroll back up to change page.
Wishing you all a merry Xmas
Andrew
Re: Ellis, one more messageboard suggestion
Not Ellis but...
David Yoho
>Andrew, actually he did that already but it doesn't work if you're using IE-6. I use it and the menu doesn't scroll down the page here either. I know there was some talk about finding a work-around but my guess is, for now, it probably got placed on the "when I find time" list.
Anyway, I wanted to let you know that feature is in place and does work for folks using other browsers.
David
Re: Not Ellis but...
>Thanks David,
I'm using firefox 2.0.0.11 on XP and only have IE on the computer to work on the occasional website which firefox doesn't work on.
Just checked and the menu frame scrolls with the board still.
THanks for the info.
Cheers/Merry Xmas,
Andrew
Carol - now in NC Nebraska
>Actually David, I use Firefox and it doesn't float for me either. It used to but since the fonts got changed there, it doesn't.
George (Oxford, NC)
>I have XP (Home Edition) w/SP1, 2, & 3, IE7.00.6 and the side menu still floats with the main body of the text.
George
John Veerkamp
>Scrools up for me too using Netscape.
John
Stuart Johnson
>Someone posted a quick tip.. Just hit the home button and you are back to the top of the page. There must be a million of these little tips floating around that once someone tells you about them they turn into a forehead slap.
Where's Dan?
David Yoho
>Bad Firefox!!! Looks like IE-7 users are seeing it okay. I don't have answers because.... well, like I said, I'm not Ellis.
David - (not Ellis)
SP1, 2, & 3????
David Yoho
>George, is there a service pack I'm not aware of for XP?
David - (still not Ellis)
Huh?
David Yoho
>What home button? The one at the top of the left index takes me back out to the main WC index page. The Return to Index link takes me back to the message list where I left off and using IE-6, might have been below the left side menu and don't see it. The home button on IE takes me to the Website I have selected for my home page.
As Arnold (Different Strokes)Jackson used to say, "Whatchu talkin' about Willis"?
David
Re: Huh?
David
>Firefox on a Mac does not let the menu float; and BTW haveing to use the back button all the time is not user friendly either. Still not a fan of the new look.
Re: Huh?
>home button on the keyboard, David.
But that's a pain.
Re: Where's Dan?
Dan Donaldson
>I'm here ;-) I am not sure why some are seeing it unless it is somehow from a cache. Ellis had to turn it off due to some technical issues. It was great for me, but not for IE6. I will sure be glad when IE6 is history. It causes no end of problems for web developers. Many of the newer CSS standards don't work properly, so you have to do two versions, one for IE6 and one for everything else on the planet ;-)
Re: Huh?
Stuart Johnson
>Yep, the home button on the keyboard. I should have been more specific. I don't find it a pain and now use it on many different sites.
>I thought I saw it posted that this had been fixed, but the fix was you had to dump your cookies and come back to the board. I have not tried that, because, uh, I don't know how to dump my cookies. Yes, I am that computer Illiterate. (I depend on lightning hitting my computer occasionally to dump them and to force an upgrade. Been very dry here lately.)
The Home button is one of those buttons I am usually afraid to touch. On my Keyboard it is between "INSERT" and "Page Up". Page up and Page down work also and end seems to do about what page down does, but I have not tried it on a really long thread. And For Goodness Sake don't touch DELETE unless you have a spare computer.
Re: SP1, 2, & 3????
George (Oxford, NC)
>I get all updates automatically so I don't necessaraly keep up with each one. I do use Belarc Advisor which lists all hardware and software in/on your computer (a free program). I ran a Belarc report this morning just so I could see which version of IE I had and the report shows SP0, SP1, SP10, SP2, SP3. Under each of those it shows some 'KB' numbers which are footnoted as 'Hot Fixes'. Under the SP3 column, the latest KB numbers are dated 12/12/07.
Belarc is really neat, you might try it to find out what all is on/in your computer.
Oh, THAT home button...
David Yoho
>Thanks, Carol. I would've never figured that one out. I mostly use my keyboard for typing. I actually had to look to find the Home button. Sheesh, who knew? Learn something new here every day!
David
Re: SP1, 2, & 3???? *LINK*
David Yoho
>George, you're a trusting soul. I can't say I'm one of those MS haters but I sure don't trust them. I like to check into the updates that are available before allowing my system to download any. It's saved me problems more than once.
Even though MS has stated publicly that IE is an integral part of Windows and woven deep into the OS, they are still two different pieces of software not to be confused. Unless I missed something, Windows XP has only had two Service Packs.
I don't mean to sound like I'm busting your chops - just want to clear up a minor technicality in case someone gets confused.
Another useful utility you might like is the Secunia Software Inspector. I use it all the time for detecting insecure software installed on my system. To make sure that your system is up-to-date, click the link below and follow the directions.
David
Sgian Dubh
>I'd like it if hovering my mouse over the links on the left menu bar actually activated the drop down (or are they fly-out?) menus as happens with my computer at work.
To go from the this main message board to the Hand Tools board I have to go back to the Home page and do some long-winded navigating from there. And I've pretty much given up trying to get to any other areas of this forum, ha, ha.
Anybody any clues why this happens? I've tried allowing drop down menus and adjusting various settings in the Firewall and stuff, but nothing's worked yet--- those fly-out menus resolutely refuse to fly out. I'm using Internet Explorer. I don't know which version. How do I find out, and does it matter? Slainte.
Rod Peterson -- Ormond Beach
>That's odd. Although I primarily use FireFox (which works like you describe you wish it would), I checked with IE6 (kicking and screaming) and the mouse over menus work there, too. I've done some drop down/out menu implementation, and as DanD has said and I've experienced, IE fights CSS hammer and tong. This particular menu seems to be okay, though.
Rod
David Yoho
>The menus work fine for me too (IE-6).
David
Sgian Dubh
>Thanks for trying to puzzle out what's going on Rod and David. I've found out I'm using IE6. I know because last night Microsoft offered to update my version of Internet Explorer with version 7. I've downloaded this version before and didn't like the look or feel of it: big, fat childish looking arrows and chunky baby looking writing in pastel blues and greays is a look I can't bear. I deleted it pronto and went back to version 6.
I've been around all my Norton and MS Firewall settings in the last hour or two and checked that I'm to allowing everything from cookies, to pop ups, to even allowing ads to show up here at WoodCentral. The result is still no fly-outs when the cursor is hovered over any of the links in that left hand column.
Clicking on the word Messages does nothing, and the same for every other option. Oh well, I can't seem to fix it, and I guess I'll just have to keep going back to the Home page if I want to navigate around the site. It's clunky but it'll have to do. As I only normally visit the main message board and the hand tools section with only rare forays into the articles section I guess this will just have to do. Thanks again for trying guys. Slainte.
How to know which version
David Yoho
>Richard, the way to see which version for sure you're using is this:
1. On the top menu of IE click Help
2. You should get a drop-down menu --click About Internet Explorer
Your version will be displayed with some other stuff.
Maybe installing the newer version (7) and then removing it "broke" something in the older version. Stranger things have happened before. As I was saying in another response, I don't allow automatic updates from MS and one reason is the way MS tried to shove their new version of IE on users. I've since selected that update to not show up in the future.
David
Re: How to know which version
Sgian Dubh
>Thanks David. I followed your tips and it's definitely version 6 of IE I'm using. I wonder if your musing on my reverting to version 6 after test driving version 7 has caused the wee difficulty? I guess I'll never know but this crankiness certainly won't stop me dropping in here and posting as I do now, ie, rather infrequently really. I go weeks, perhaps a month or two and contribute nothing, then I'll post three or four times in one day, ha, ha.
In a similar vein to yourself I don't allow Microsoft to automatically update the software with downloads. There's an option I've selected that lets me view the downloads available and decide which ones to install. I always refuse the option of IE7 now, but I haven't blocked its availability.
Anyway, I do appreciate your tips and thoughts, and all the best for the Christmas coming and the for the New Year. Slainte.
Sgian Dubh
>Rod and David, just a follow up on the none appearance of fly-outs, or whatever they're called with my computer since ever the change occurred here at WoodCentral.
Today, for no apparent reason I can think of they work. I've changed nothing. The only thing I did, and it's what I usually do, is turn off my computer last night when I'd finished working on some projects and booted it up again this am, about half an hour ago.
It's a mystery, but there it is. Fly-outs are flying out all over the place and I've got easy access to the whole WoodCentral site again.
I think I'll have a drink. Oh, better not! It's only 10 am, and a bit early in the day to get all tired and emotional, and slurring in vowels, ha, ha. Slainte.
