Veritas - Innovation in Tools
How long can wood sit before milling
Jay St. Peter - Southern, MD
>I found some Cherry that was cut last January and piled in someones backyard. They were expecting someone to come get it but they never did. It has been offered to me to haul away and I'm wondering if it's worth it. I have a friend a couple houses away with a tractor and trailer that we can use to take it to a local menonite sawmill. I'd love to have the wood, but am I too late after a year or will it still be good. If the answer is "it depends", please let me know what to look for if I go take a look at it one day this week.
Thanks,
Jay
Re: How long can wood sit before milling
Greg Haugen
>I'm assuming this is still in full logs, not split or cut yet. Here's a few thoughts on cherry. At least for me, it seems to start cracking and splitting as soon as it hits the ground. If they're large enough logs, this still shouldn't detour you yet. Your yield will be smaller though. Cherry is one of the woods that also doesn't decay or rot as fast as others. I'd look at the ends to see the amount of checking, it will give you a rough idea of how deep it goes. Has it been tarped at all? If the price is "Free-you haul" and you have means to do so with giving your friend a few beers for his time-it's worth a shot. Especially if it doesn't work out (if it's really checked up or marginal)-if you have a woodburner then go for it. *I know, I'm going to get chewed out by the "cherry fanatics" for suggesting to burn cherry.*
Just my 2 cents,
Greg Haugen
It depends....
>It depends...... does the tractor have enough gas in it to make the trip to Atlanta ;)
Seriously though..... you're talking logs, right? Not planks. Do you turn bowls or are you thinking about milling into boards? Was the wood resting directly on the ground and was it covered with a tarp or just sittign there on the ground?
I don't know about cherry, but I cut down some oak and had it sitting out back, and the stuff that was on the ground left unprotected rotted very quickly. But the logs that were lifted up off the ground and kept dry only checked and got a little moldy at the ends, but didn't get ruined like the stuff on the ground.
Happy Woodworking!
Re: It depends....
Greg Haugen
>Mark, curious-was it red or white oak??
Greg
>I haven't seen it, but my impression is it is sitting on the ground and apparently covered in leaves. It will be burned if I don't pick it up in the next couple weeks. I'm mostly curious if the yield will be worth the hassle and milling fee ~$0.20/BF IIRC. I guess I'll have to go give it a look. A buddy had some oak milled after a year on the ground and wound up with very little useful lumber. I was mostly wondering if there were some rules of thumb about these things. Sort of a don't bother after xxx time.
One experience
Ed Mulligan, Cape Cod
>I just cut up a large (24" diameter) cherry crotch. It had been laying on the ground in a shaded area, covered with leaves, for 4 or 5 years. I fully expected it to be badly checked and split, but it wasn't. Instead, it was still quite wet and the checking on the cut ends was minimal.
By contrast, some 4" diameter cherry branches nearby had turned to mush in the same time frame.
Ed
JohnKJordan in East TN
>I'd take a chain saw and cut off one of the ends to take a look. If it's cracked badly 8" or so in, try cutting 8" further. After slicing, look at the sapwood where it's been in contact with the ground and see if it's rotten or buggy. Sometimes the sap wood will be ruined and the heartwood will be fine. Sometimes you get fantastic spalting after a year or so!
BTW, I've cut hardwood logs on my sawmill that sat for one and two years and got a lot of good wood - y.poplar, oak, walnut, etc. I cut a cherry last fall that had been down since spring and had no damage. Usually pine (virginia pine around here) goes the quickest on the outside but the center is good. Sometimes just 1/2" or so under the bark is bad.
Robin Corell in Atascadero Ca
>in the realm of it depends variables one of the more pertinent is how big is the log. the smaller the log the more rapid the degrade. not sure how chery degrades as I have never milled any. I spent one day a week all last summer milling 28" diameter walnut trees that were removed over a year ago. The boards had very little checking, but walnut in general is much better behaved than most other woods.
I would recomend measuring both ends of each log as well as the length and then asking the mill operator for their opinion as they are likely to be the most knowlgeable about how rapidly cherry logs degrade in your area.
Robin
White Oak
>It was white oak which is prone to rotting around here. At least so I've been told and my experience seems to support that.
Happy Woodworking!
Re: White Oak
Greg Haugen
>That seems odd since White Oak is one of the best woods for outdoor applications.
Greg
Jay St. Peter - SoMD
>Thanks guys. I guess I'll take a look at it. If it looks reasonable I'll drag it to the mill and see what I wind up with.
Jay
