problem with thickness planer
Cody Lewis
>I have a Rigid thickness planer that has worked well for me for about a year and a half. However, on the last few projects I've done, the piece I'm planing "sticks". In other words, the black rollers that are designed to keep the piece moving thru the planer don't grip the wood enough. Instead the wood stops and the black rollers peel out against the wood, leaving a black stripe. In the past, I've just nudged the piece thru the machine because it was very rare that it would stick, but now every piece stops mid-stream and sometimes I have to push or pull the wood thru with TONS of effort. It's okay I guess on the projects I'm going to paint because the black stripes get covered up, but on projects that I'm staining with a light stain, I have to spend tons of extra time getting rid of the stipes.
In an attempt to correct it, I wiped all the sawdust and wood chips off the black rollers with a rag, but it didn't fix it. It seems to me like the rollers are not tight enough against the wood relative to the blades, but I can't see how to make any adjustment there.
So here are my questions:
1. Is this a common problem in thickness planers? or maybe it's common to this Rigid brand???
2. Anyone know how to correct it?
3. Should I have paid the $200-$300 extra to get a much better thickness planer?
4. If the answer to #3 is yes, anyone wanna buy a Rigid thickness planer (joking).
Thanks for any help all you experts can give. You have been very helpful in the past.
