Make your own
Lee Schierer - McKean, PA
>It is really easy to make your own dowels on a router table in four passses. All you need is a table mounted router, a router bit with the proper radius and good fence and a feather board to hold the wood against the fence at all times. Set the router bit so the top edge and bottom edge are flush with the fence and table. Place the feather board so it will hold the wood tight to the fence. Cut a piece of wood the length or slightly longer than you will need. This piece of wood should be exactly square and the same dimension as the diameter of the finished dowel you want.
Then feed the wood through the cutter. Rotate the piece so the area you just cut is now up and agianst the fence. Make the second pass. Rotate the stock the same direction again, always keeping the flat side on the table and the corner to be rounded down and toward the fence. On the final pass you will have one square corner left and you will be cutting that away as you push it through the bit. Be careful on the last few inches as the piece may tend to rotate as you push the last of it through.
Use a push stick for all passes. Make all the cuts full cuts to the finished dimension this is one time you can't sneak up on the finished size so watch the grain direction when you start to avoid tearout.
Some people like to leave 3-6" of square stock on one or both ends to prevent rotation of the piece during the cuts, I've found that this isn't necessary, but if it suits you do it.
Lee
