Brass in a chop saw ?
Barry Rubenstein
>Would I damage my carbide tipped saw if I cut .125" brass rod in my chop saw ?
Re: Brass in a chop saw ?
Dick Coers
>I think the blade would be safe, but I would really worry about a catch/kick from the blade grabbing the small rod. Maybe if you buried the rod inside a block of wood, then cut it through the wood and the rod together, it would be okay. The rod by itself would be dangerous.
>I would use a bandsaw or a hacksaw.
Thomas S Stockton
>Should'nt hurt the saw with a non ferrous cutting blade. The concern is hurting yourself, round objects tend to want to spin and become unstable when cut with a spinning saw blade so figure out a way to clamp it and your fine. I use a hacksaw, brass is really soft and takes very little effort to cut. I then clean up the ends on a disc sander because I was always told not to use a grinding wheel on brass.
Tom
Bandsaw with a 6-10 tpi wood blade
Garrett in Victoria
>will do what you require easily, safely, and without damaging the blade.
Cheers, Garrett
1/8th" rod??? Power tool is overkll
Chris Knob
>Coping saw with a fine toothed blade. Using your chop saw on this is like using a backhoe to plant your vegetable garden.
And it wastes compost!
Art Silva
DANGER DANGER, Will Robinson
Pete in Holland
>Cutting with a saw normally recommends at least 3 teeth be in contact with your work at on time, else you run the risk of the blade plunging into your work piece and either; A) shattering the teeth from the blade, B) having a tooth grab the 1/8" wire and pull it thru the fence, taking your hands with it, or putting your hand/body at risk while the wire is wrapped into your saw.
Wrong tool for the job.
Re: DANGER DANGER, Will Robinson
JohnKJordan in East TN
>If you want to cut thin stock of any kind with a power saw, you can sandwich it between thicker stock and clamp the sandwich to the table or fence. Thin brass and aluminum can be sandwiched between pieces of wood. This works for rods, bar, thin sheets, etc.
Larry in NW Ohio
>If the rod is only 1/8" I`d just use a side cutter or a hacksaw, then no one will get hurt. Be careful. Larry in Ohio
Barry Rubenstein
>Thanks. I get the message.
JimM
>Barry,
Cutting 1/8" brass in a power chop saw or a bandsaw is just plain dumb - period. Spend $4, get a cheap fine tooth hand hacksaw and cut the brass half way through. Bend it and it will break off, file the rough edges.
Sure beats setting in the ER waiting to have a piece surgically removed!
Re: NO NO NO
Brian in Brighton
>you can cut it fine, but not that small. It will grab it and pull both sides into the blade and guess what will go with it.
You might be able to put it into a groove in a piece of wood and cut the whole thing safely.
Just use a hack saw.
Brian in Brighton
