Basement as "kiln" question?
>Went and talked to my Doctor yesterday and an actual conversation broke out. Turns out he is a wood worker and also has a bandsaw mill that you mount on the log and push through the wood manually. He mentioned he built a new house with a basement and that he had 5000 feet of lumber in there he is drying by running an AC inside. I gathered he was running a small window unit totally inside the basement. (Not sure, it was a brief conversation.) He commented that his basement was at about 75 degrees and so humid that when he came in from outdoors his glasses fogged up.
I can see how this would be a good way (maybe) to dry the wood, as long as you didn't let it get moldy, but my question is about the house. As a Home Inspector, I see houses all the time that are damaged by wet basements and wet crawl spaces. (In fact, those are usually the overwhelming sources of moisture) Putting 5000 BF of green lumber in your basement would mean you have hauling in literally tons of water. Isn't the house and particularly the floor above going to try to equilibrate to the wetness of the new wood? And, if you had some lumber that was dry and you had it in the basement and then brought in a huge new batch, wouldn't the MC of the older stuff rise? Am I the only one who sees this as not such a good idea?
