THE WOODRAT IS BACK!
Compressor Kit
Compressor Kit
Compressor Kit
Larry in NW Ohio
>I`d like to buy a compressor/ nailer kit for Christmas for my son. I`d like opinions about the various kits out there. Which one do you have and do you like it. I saw one in HD last light for $200 marked down from $250. It was a P-C with a compressor a pin nailer, and a pad sander. Any opinions. TIA Larry in Ohio
Re: Compressor Kit
Re: Compressor Kit
JohnKJordan in East TN
>Years ago I bought a Porter Cable pancake compressor and brad nailer combo. I've been quite happy with it and use the compressor often with staplers, brad, and framing nailers as well as several rotarary air tools. $200 sounds like a good deal to me if you need the air tools.
Re: Compressor Kit
Re: Compressor Kit
>I bought a pancake compressor with nails guns kit from HD about a year ago. The box was battered and tattered and one of the guns was missing. They had it marked down $100 or more. I did not need the guns, but a friend and I decided to split the package. Got it home and plugged in the compressor and it smoked. Took all of it back and got the money back.
Went to Harbor Freight and bought a 1 gallon Campbell Hausfeld compressor for about $70. I like it fine, but it is really small for big nailers. You can drive larger (framing) nails with it, but practically one at a time. OTOH, it will just about fit in a five gallon bucket and is light to carry around. Very handy for small jobs. Friends have found out I have it and it spends a lot of tiem visiting their projects.
Re: Compressor Kit
Re: Compressor Kit
Chris Knob
>PC pancake is fine for modest nailing...brads, finish nails etc. It's gonna run a lot if you take it outside and frame a building though and forget air tools or spray guns. They will kill this noisy, oiless compressor in short order. Rubber re-inforced pressure pressure tube from the tank to the pump is usually the first thing to go. Very difficult owner repair as the plastic pump housing has to be removed and PC uses very special head screws to put it together! Crafty devils.
Re: Compressor Kit
Are you sure he wants a Pin nailer? Pins are tiny.
Dave Bair, Eaton Rapids, MI
Re: Compressor Kit
Re: Compressor Kit
ScottS
>I bought one of the Porter-Cable compressor kits a couple of years ago. I got a pancake compressor, brad nailer, and finish nailer. All of the tools work as advertised. Unfortunately, I find that I don't use it much. The compressor, being an oil-less design, makes SO much noise that I can't stand to have it anywhere near where I'm working! Even 50-feet away, it's still annoyingly loud! Of course the tank is small, so the compressor runs often.
If you're sure you'll use air tools, my suggestion would be to invest in a decent oil-lube compressor and buy tools as needed. You'll end up spending a bit more money, but you'll also have a better (and quieter) setup...
