Interesting consideration gluing a edging
Link Van Cleave
>I need to glue a piece of Wenge on the edge of some 3/4 plyboo bamboo plywood to make a table top. The plyboo is 3 layers of bamboo alternating grain. Although bamboo is a grass I am assuming it behaves like wood as far as glue strength. The Wenge edging is 1 1/8" thick by 2" wide. When you look at the edge of the plyboo you have roughly 3@ 1/4 layers. So on the long edge you have side grain gluing on the two out side layers, maybe 1/2" decent glue surface total. Not a lot but at least being the 2 outside lams in good structural position. Plus a spline in the center will be cutting into end grain only so you would get more glue surface, alinement, and some mechanical strength. The dicey part as I see is at the ends of the table where a spline is out of the question as it will cut into your only side grain gluing, and you only have about 1/4" side grain glue surface and it is in the very center of the edge, not the best place for strength. The edge is 2" wide, a lot of leverage could be applied by someone leaning or sitting on the edge. In my glue consideration I am thinking of epoxy for the strength it would give me on the end grain surfaces. Mechanical as opposed to chemical bonding. I will do a test today. Yellow glue, poly glue, and epoxy with and without splines. I will post results.
Link
