I zigged while others zagged
Grant in Iowa
>back when I began "tooling up" my shop, I decided I wanted a nice long straightedge for tool setup purposes. I think someone here recommended a flooring installers straightedge.
These straightedges, such as the 6' one from Crain that I bought are guaranteed straight to within .005" at the time of sale, are made of 3" wide steel, and ground flat and straight on both edges. While a machinist might turn up their nose at such a loose tolerance, I have found it straighter than anything else in my shop...trust me, I have no flat cast iron... I checked when I got it home.
I have used mine quite a bit for setting up new machinery, or recently moved machinery, in and outfeed tables, and for checking the results of jointing for the purpose of tweaking the jointer for a perfect fit.
When I built a table top, I was able to check the edges of each board after jointing to make sure they were straight. This repeated checking and rejointing served to hone my technique at the jointer such that I could make 6' boards that mated together perfectly.
Anyway, I'm not sure what you are needing a straightedge for in your shop, but if you want a long one that is tough, straight, and reasonably priced, visit your local flooring supplier and pick one up. Mine was about $40 for a 6 foot Crain. Just google "flooring straight edge".
FWIW,
Grant in Iowa
