How to mount corbel
How to mount corbel
How to mount corbel
Brian in Brighton
>I am making a pair of corbels for under our upcoming mantle and for the life of me I can't figure out how to secure them to the slate tiled wall. They are about 20 inches long, 8 inches deep and 5 wide, made from walnut and will support the mantle. Any ideas of how to mount these monsters?
My only thoughts are to make a pair of giant dovetail keys that I can secure to the wall at the proper height and then slide the corbels on them before mounting the mantle. This would allow me to make them heavy duty to hold the mantle and yet have the corbels have no visible mounting hardware.
Cutting the slate is out of the question and still leaves me with the need to mount the corbel to the wall.
I sure with I could post a picture easily without having to use a thrid party blog to hold the pic. Haven't tried it in a couple years and the lame blog I used does not recognize me as I don't have any desire to keep one up. I'll try to attach the picture as a graphic upload.
Brian in Brighton
Re: How to mount corbel
>How about some large french cleats? I used them to mount my workshop cabinets to my cinderblock shop wall. I admit you can also use your dovetails - but maybe the cleats would be easier.
Re: Same principle, just long and narrow
Brian in Brighton
Robin Corell in Atascadero Ca
>If your corbels are hollow you can mount a ledger on the slate with leads or toggles. The leads should go into the brick behing the slate and if there is sheet rock and no brick you should use toggles. A squirt of adhesive between the ledgers and the tile would also be a good idea. Then shim the corbel to the correct height and pop a couple of finish nails to secure it in place. Depending on the size of the corbels you may also want a verticle ledger near the outside to help secure it as well. years ago I used to install plaster mantles and this the method I used.
Robin
tstock
>Don't worry about the corbels - mount them to the mantel. Run a hanger bolt into each joist at mantel height, rout a 1/2" x 3" slot for each bolt at the back edge of the mantel. By extending the slots by 1/2" at each end, but at only 1/16" depth, brass or aluminum cover plates can be mounted to cover the fastener access.
Here's a section view through the mantel showing the basics of the mounting system. On the plus side, total damage to the wall is hole sfor the hangers...that's it.
paul waddle
>I am interested in the same thing,but about 3months away. I like the idea of drilling and putting anchors into the wall. I want it to be sustantial and I think anchoring an "under board" and making a hollow in the corbel for it, is the way to go. One of the other contributors mentioned this method.Its sorta a french cleat. pw
Mike Fitterling
>Perhaps you could make the backs of the corbels slide into grooves from the bottom of the corbels. You can then mount the backs to the slate, then slide the corbels down onto the backs. Make the back like a reverse raised panel, either actually raising them or making them of two parts--one the width of the groove and behind this, but not quite as big and centered another piece equal to the distance between the groove and the wall.
Good luck,
Mike
Re: Thanks again
Brian in Brighton
>Nice to repeat earlier posts that you folks are the best. No laughing or finger pointing or anything. Thanks to Ellis and the drew for keeping such a great asset going.
I will try to figure more stuff out and post it later when I'm done.
Brian in Brighton
