Band Saw Tires
Bill Blasic
>Any ideas as to installing band saw tires as they seem pretty small. Do they have to be strecthed or anything?
Thanks.
Band Saw Tires
Bill Blasic
Thanks.
Re: Band Saw Tires
Harvey Brooks, Victoria, BC
>The urethane replacement ones have to be boiled and then installed while they're hot and flexible. They'll shrink tight in the wheel.
Harvey
Re: Band Saw Tires
Bill Blasic
>Thanks Harvey, very much appreciated.
Re: Band Saw Tires
Robin Corell in Atascadero Ca
>I'm not sure that boiled is the right word. they really only need to be heated in hot water. I found it easier to dry them off before installing them. the directions say to add a couple of drops of liquid soap to the water to make them slide on the wheels easier. I found that they were too slippery and needed a bit of friction so I could get them to stay at one point on the rim as I streatched them around. I was susspicious of how they were somewhat moveable even several days later. I installed them on my 18" parks last November and have used it heavily since then with nothing but good results.
Robin
Two extra hands needed
Lee Schierer - McKean, PA
>On the 16" saw I installed some on, they were tight and the cold metal cooled them pretty quickly. I could have used a couple of extra hands to get them on. I've heard that you can use some quick grip clamps to hold the starting point so you can work back around to get it all on. Some of those plastic pry bars for bike tires might also prove useful.
Lee
Re: Band Saw Tires
Bill Falberg
>I put all of mine on cold. It's not hard if you clamp your wheel to a good, solid built-in table top and use all ten fingers to wrestle it around. Having the wheel real steady lets you put your weight into it. I can do about thirty an hour that way and it saves heating water and all. Plus I'm not sure the polyurethane likes being heated that much. I've had problems with tires becoming ovr-heated and losing their elasticity; whether boiling causes any loss or not I don't know.
Re: Two extra hands needed
wilbur
>That's exactly how I installed my tires. I used a clamp to hold the tire in place, and a pair of thin flat sticks to pry the tire onto the wheel. Using one stick, I worked the tire onto the wheel starting from the clamp in one direction as far as I could go, then used the stick as a wedge to hold that part of the tire in place. Then I used the other stick starting back at the clamp and working the opposite direction. Then I just worked back and forth between the two sticks.
It was just like changing a bicycle tire.
Re: Band Saw Tires
Keith Newton
>When I have done it, I clamp it to the top of the wheel, then pull it down and clamp to the bottom, then pull each side out like drawing a archery bow.
