>Anyone have experience spraying lacquer over tung oil? I've seen posts that recommend using shellac over oil then lacquer. But I'm wondering if it is a step that is necessary. Thanks for your help with this.
>I can only give you my own experience and it was with BLO rather than tung oil. The king bed I just finished was oiled with a 50/50 mixture of BLO and mineral spirits. Let set for a short time, then wiped off. After letting the oiled wood dry for a week, I went back and applied three coats of nitrocellulose lacquer. I had no adhesion problems and the bed looks good. I think the secret is in letting the oil completely dry before applying the lacquer. I would think tung oil would be similar.
>Ken, my only concern about doing this is the amount of tung oil applied. If it's only a thin coat or two, probably not a real issue. Real tung oil is a reactive finish. Once it cures, the film is harder than that of linseed oil but still on the soft side for a finish. With a thicker coating beyond just one or two thin coats, I'd worry about the harder lacquer being over the softer oil. If your concern is just - will it stick? - as long as you allow ample drying time for the tung oil, there shouldn't be a problem.
