Trouble face jointing birch *LINK*
Dan Mitchell
>I'm having difficulty getting flat surfaces on some birch I am trying to face joint for a glass table base. The boards are about 27" long, by 3 1/8" wide, by 1 3/8" thick. I have posted some pics at the URL below. Basically, I am running the boards through my table saw. The non-faced surface (against the fence) s flat & the edges are 90 degrees to the faces. Since the width exceeds what can be cut w/the 10" blade, I have set the blade a little over half way up the width of the boards, made a cut, then flipped the boards & cut the other half. The cut is about 1/16, so less than the 1/8 kerf. As shown in the 1st pic I have 2 sets of fingerboards pushing the stock firmly against the fence before & after the blade (again, there is no waste due to the thin cut). While the faces look smooth (pic 2) they are in fact slightly convex. As shown in pics 3 & 4, when one edge is clamped, there is a gap of about 1/32" on the opposite side of the joint. I know a planer should be used for this, but I don't have one, plus it seems the saw should be able to pull this off. Blade is exactly 90 degrees to the table, according to several squares. HELP!!! :-)
TIA,
