>Are there any Deft lacquer to Crystalac lacquer converts out there? I've only been spraying for about a year and I have enjoyed the results of Deft. However, if Crystalac gives similar results without the smell and clean-up hassels I would be willing to give it a try. Opinions? Thanks for your help
>Ken, as I stated in the Deft thread below this, I have used Crystalac. I got mine from McFeeley's. I can't say I use it often but will whenever I need to spray a lacquer finish. I have several other go-to finishes I prefer using. The Crystalac is a good product and seems easy to use. I really like the fact there are no nasty fumes and clean up is a breeze.
>I have used deft for many years and have sprayed it in the past. I swithced to brush only application a while back in an effort to cut down of fumes. I have sinces switched to Generals HP and I have been much happier with the performance of the finish. truely non yellowing, near water proof ,much more abrasion resistance, and with very similar application charicteristics.
I have a friend who makes drums and had been using deft with a HVLP rig. he switched to Crystalac and likes the results so much he recently gave me a quart of the brushable to try. I have seen his drums sprayed with the crystalac vs the deft and the crystalac is much clearer and harder to the touch and cures much faster. He uses the anti fish eye additive as well as the pore filler. The pore filler is a thick paste that is applied with a plastic spatula and then lightly sanded. it dries just as clear as the finish.
once you get used to the finish raising the grain and dealing with it I think you will actually be much happier with the results than what you are getting with deft.
Robin
Ps Crystalac sells a gun cleaner for any finish build up over time or if you leave your gun and forget about it for the weekend. I am told this stuff world great as well.
