If it's good enough for Broyhill...
Charles Wiggins
>When I worked at the furniture store the finer case furniture came wrapped in thin, flexible foam sheets with three-faced 'pyramid' corner covers. The corner covers were generally made of compressed paper, but they were sometimes made of corrugated cardboard, and I've made them myself easily enough. They are usually around 4-5" on each edge. Check with local furniture store warehouses to see if they can spare some - don't bother with the store itself - go straight to the warehouse. We always kept a bag of foam sheets and a box of corner covers just in case we had to ship something back.
I've never shipped anything intricate, but I built a few crates for framed artwork and some fairly heavy metalwork. To cushion against shock I usually use 3/4" or 1" blue or pink insulation foam board on the inside wall of the crate. I would dimension the crate to barely allow for the thickness of the foam so I had to compress it oh-so-slightly to close the lid and screw it on. It's great because you can cut it or carve it or glue it up in layers to accommodate surface irregularities or hardware. You could even make your corner covers out of the foam and some duct tape if you need them. I used Liquid Nails to fasten the foam to the crate wall (if the foam has the plastic sheathing be sure to peel it off first - you'll get better adhesion on the bare foam). It's better to leave the plastic sheathing on the side of the foam facing the product because the foam itself is pretty abrasive. I would still get the thin foam sheets or some cheap packing blankets to protect the finish, and of course you'll need to allow for that when you dimension your crate.
Good luck!
