>In the process of making plantation shutters for several windows, one must drill 9/64" holes for shutter pins in the ends of hundreds of louvers. Norm and others suggest building a jig to hold the louver vertically at the drill press. It seems like it might be easier to use a Jacobs chuck at the lathe to hold the bit, and build a cradle to align the louver with the bit -- then just slide the louver into the spinning bit. Or perhaps I missing something? Thanks for your observations.
>With hundreds to do, I think I'd take the time to experiment with both methods and see which was easier, faster, and more accurate. Having neither a drill press or a lathe at my disposal I would have to try making a jig that would fit over the end of each louver with some sort of bushing as a drill guide and use a had-held drill. Maybe that thought will shake something loose and help you decide.
Here's my solution for a drilling operation similar to what you described. A drill press table like this wouldn't have to be as elaborate, but a simple one using the same idea wouldn't be hard to make.
>I used to have s recuring job making the half circle and eliptical shutters for a company that was set up for production on the standard shutters. The company had a 70K machine that cut the louvers to length and drilled the holes in the ends.
My solution was to buy a cheap delta bench top drill press( I think it was $99, 5 or 6 years ago.) I made a box with a couple of holes on the ends for the collumn and took the base of the press off and slid the collumn into the box and turned it sideways to use as a horizontal boring machine. Because I had a single use In mind when I made the box I made it at the exact dimensions to drill the holes in the end of the louvers.
I made my box out of 2" thick elm and after I iserted the collumn I drilled holes trough the wood and the collumn so I could insert roll pins. this made sure that the table height would never change. You could modify this design to alow the height of the table to be adjusted by rotating the collumn in the box but then you would need to come up with a way to clamp it.
In use my horizontal press paid for itself several times over. For drilling the end grain holes I found it best to use a brad poit bit and relatively high cutting speed and moderate feed rate. I made my own pins out of 3/16" dowel rather than the plastic ones because on some of the eliptical shutters I needed the smaler size and longer length. I suppose you could make your own 9/64 brad point bit if you don't have one.
I no longer have the drill press or I would send pics but If you have any questions please don't hesitate to ask.
>Thanks for the replies! It's always fascinating to learn how others have approached a challenge like this, with several options for tooling up for a task.
Slightly OT, recently I've been reading Witold Rybczynski's "One Good Turn" which pays homage to those with a mechanical bent, from Archimedes to Europeans to Americans. Highly recommended little book!
