REAL MILK PAINT
Sawing close to wall
dalegolf
>My daughter gave me a challenge. Find a way to cut out 3/4" sub-floor
within 1/4" of the wall. We have approx. 120" to cut out. I need your help on this. We could do it w/a hand saw but would rather use power saw if possible. Skill saw, reciprocal, sabre, etc. do not cut that close to the wall. Any help identifying a means of doing this w/b appreciated. Thanks
Re: Sawing close to wall
Gary Camp, Bend, Oregon
>Check at your local industrial flooring supply company. I've seen a saw that looks like a cross between a hand saw and a hedge trimer. It is made to do flush triming but I can't remember what it is called. It might work for you. Or you might try an offset base on a trim router, I think mine will get within a 1/4 inch, but you made need a narrower kerf.
glc
Lee Gordon
Re: Sawing close to wall *LINK*
Lee Gordon
>You can get an offset blade adapter for a reciprocation saw. The one in the link below goes for about $40. Milwaukee makes one for some specific Sawzall models for about $15.
Offset Adapter
Larry in NW Ohio
>Just a quick thought , could you use a biscuit jointer. I used mine to uncut wall molding when we put down genuine, imatation, wood flooring. Worked pretty well. Larry in Ohio
Bill Falberg
>If you take the platen off your jig saw and tilt it forward, like you were going to start a cut without drilling first, you can control the cut depth by the angle of foreward tiltage. At the same time you'll need to angle your blade to the side such that you're cutting right next to the base-board (and in fact fact using that as a guide for your cut). This gives you a slight undercut, but removal should be easy enough with the interior plates already gone. I hope you're not expecting a smooth finish on that. If you were in a hurry to get it done you could sharpen the point of a jack hammer and chisel it out. There's less sawdust that way but it can be hard on the walls.
That's a new one to me
Michael Stadulis, in Gloucester County, NJ
teflon_jones
>What you want is called a toe-kick saw. They're a pretty specialized tool and they run about $200. You could also go with that Sawzall adapter, but I don't know how well those work. You're also going to have trouble when you get to each joist. The good news is that if you bought a toe-kick saw, you could probably sell it on eBay for not a lot less than you paid for it. Here's a link to what they look like:
http://www.coastaltool.com/cgi-bin/SoftCart.exe/a/crain/795_toe_kick_saw.htm?L+coastest+vrwz7690ffab5aab+1191935208
>There are flush-cutting saws for this operation which you can rent from a good rental outfit or a wood floor jernt that caters to consumers. I have also done this with a Lancelot carver on a mini-grinder with the shield in place. You should also wear a full-face shield. You do have to be sure to remove all iron in or near the cut line.
You are planning to put supports under the new joint right? We bridged the joint with a 6" wide piece of 3/4" ply which was then glued and screwed to each side; floor's rock solid.
mm
Phil in NJ
>Have you looked at one of those fein multimaster machines?
I don't have one, but they seem to be able to do that kind of thing.
Fein Mult Master
Curt Harms
>That would be my choice. The things are expensive but for operations like you're planning they're the best thing I know of short of the toe kick saw. Multi Masters are also good for tile work, scraping caulking, detail sanding etc. The cutters are EXPENSIVE but they could probably be resharpened.
HTH
Curt
Re: Fein Mult Master
Glenn Madsen near San Francisco
>I have one, and it would work pretty well. But 10' of cutting would have me reaching for the Advil, I'm sure.
The cutter can be resharpened with a Dremel and a small cutting wheel. And it cuts anything pretty well. Nails, screws, no problem.
JohnKJordan in East TN
That was my first thought - I have one and from what I've used it on so far, it seems like it would do the job but be pretty slow.
John Ballance
>Here's another option - just looked this up on Ebay -- try searching for toe-kick saw. There are several options.
Good luck...
Ebay Toe-kick Saw
>How pretty does this have to be? If it is just a rough cut to remove something and it will be covered later, I would do it with my Sawzall. Put a 6" bimetal roughing blade in it and have at it. You can rest the end of the shoe on the floor and tilt the saw. Once you get started its fairly easy, but the first six inches may be wild. If you keep the saw nearly horizontal you can cut the top layer and not cut through a bottom layer. Its a 20 minute job, but neatness does not count.
for that might as well buy direct from HF
Jack
>http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=94626
Scott Greaves in Blackfoot Idaho
>Hi Dale,
Crain makes a wonderful flush-cutting trim saw. They also make great toe-kick saws. I went ahead and just bought the flush-cutting trim saw, and have used it many time on many different kinds of projects. It is a great saw to have around if you are going to be doing projects for family! Professional flooring installers use these saws to undercut door frames so you can slide flooring underneath. Find out who sells to professionals locally, and they probably rent these things out for a small amount. Oh, and don't forget that they are dangerous, so use caution!
Scott.
Coastal Tool
