trailer floor decisions
Carol - now in NC Nebraska
>Aluminum plate WAAAAYYY to expensive. It would cost more than I paid for the trailer. Talk about a silk purse out of a sow's ear! But a nice thought, Eddie.
Trex - needs more support that the fame provides and kinda pricy as well.
White Oak, solid decking, etc. - They warned about drilling more holes in the frame, as that would weaken it.
So, plywood it is. Adds to the structural integrity of the trailer, relatively inexpensive. Gonna take two sheets though. PT stuff is pricey and ugly and requires different fasteners.
I will go back to my original intention. Some plugged CDX with more than 3 plys, oil primed and epoxy painted both sides and all edges, fastened down with the included carriage bolts. It will be parked so rain, snow, and other crap will slide off. I will mortise out for the hex bolts on the frame and then apply a thin smear of axle grease between the metal frame and the painted wood to block out trapped water. The holes for fastening it will be drilled before painting so as to slop some paint into those holes as well. Thanks Gary and others for reassuring me.
Thanks, folks. You helped me wade through some options and justify my decisions.
BTW the ramp is having an expanded steel sheet welded to it. That way items with smaller wheels can roll on and off, and air can pass through when zipping down the highway.
And when my turning skills are worthy and I get a bigger lathe, I will put a hoist on one corner to lift and swing gorgeous hunks of burls, spalted, curly, and bird's eye unto my multi-functional woodhauler!
