1 / 2 shop light . . .
SteveM
>Finally bought some new florecent tubes for the shop light today. I always thought ONE of them was bad but lived with just one working. Replaced both today and, still, only one works. Without a degree in electrical engineering, any trouble shooting average idiot can do ? Or do we junk my expensive ( $ 12.00 ) fixture ?
Re: 1 / 2 shop light . . .
Larry in NW Ohio
>SteveThere is nothing to redoing fluoresent lights, because I`ve worked on them and they all, or most of, or maybe some of them actually worked after I fixed (?) them Really they aren`t hard to work on. First off switch the bulbs and see if that may do it and also make sure the bulb is good. If not UNPLUG and take it apart so you can get at the wires and see if any are loose and if you are getting good connection everywhere. Try this, and let us know tommorrow. Larry in Ohio
Stuart Hough
>How many other lights do you have on the same circuit? I have that problem, until I plug in my tabletop drill press and turn it on. Then , when I turn the DP off, the last bulb magically pops on. I know I have a bit too much on that ciruit, but it'll have to wait until I upgrade the service with a seperate panel (and service for he garage...er shop by itself).
SteveM
>OK, both bulbs work in the good position. Took the end caps off ( after unplugging ) and could'nt find anything loose. A small circut card, transformer and a cylindrical silver whats-it at both ends. Nothing loose or discolored. Everything with solder on it is connected to, well, something. Put it back together and turned it on and jiggled the wires that run legnthwise. Still a no go.
Dan Donaldson
>I would guess that it has an electronic ballast that is going bad. Are the bulbs T-8's or T-12's? If T-8's, then I am guessing ballest for sure. It would probably be cheaper to replace the fixture than the ballast.
Re: For starters... ;^)
Al Stokka - Cambridge, Iowa
>Steve,
Those "cylindrical silver whats-it at both ends" are probably starters. Get a replacement (Home Depot, hardware store) and the problem may be solved.
Al
Expensive at $12?
wilbur
>By the way -- $12 doesn't seem like that much for a 2 bulb fluorescent light fixture. When I outfitted my shop with 4 foot 2 bulb T8 fixtures, they were about $40 each.
What I got was a better quality ballast, which means almost no buzz coming from the fixtures, and wider spacing of the bulbs, which means more even light dispersion.
Doing a quick check of the borg websites, I can't even find a two bulb fluorescent fixture for $12.
Well, that was . . .
SteveM
>eight years ago when I outfitted the shop. Went down this morning to look just for kicks. They're twenty bucks. Looks like it goes back up and we live with one bulb for awhile longer. If I just change it out I figure I'm pitching out ten bucks worth. When you work for yourself you squeeze out every penny.
