New table saw suggestions
Kenny-Middle Tennessee
>Hey guys. I get to buy a new table saw in the $1200-1500 range. I was leaning towards getting a Delta table saw. I started looking at Grizzly Table saws and it seems like you get a lot more saw for less with Grizzly. I currently have the Ryobi BT3100 so I dont have much experience in cabinet table saws. Are left tilting blades better? I tried to search the archive to see if this type question has been asked and didnt get far. Any suggestions you have would be greatly appreciated.
Re: New table saw suggestions
Robin Corell in Atascadero Ca
>I own a jet left tilt cabinet saw that I purchased new in 1999. I have had no problems with it and have been very happy with it. I decided on jet because I liked its quallity better then the PM 66 or a unisaw at that time. I did not compare it to a grizzly because I didn't know anyone with one and I wanted to put my hands on what I was considering before spending that much money. The one critizisim I have of the jet is common to many brands and that is that the melamine table is very poorly made.
I have been making my living working with wood in one way or another since 1987. I have spent more time on left tilt machines than right tilts and for that reason more than probably any other I prefer a left tilt to a right. It is generally considered safer to have the blade tilting away from the fence. this means that on a right tilt machine the fence needs to be moved to the left side of the blade for angled cuts, which usually has less capacity and is less familiar. right tilt guys have their own valid reasons for their prefrences. like I said I really think it has more to do with what you learned on.
Robin
>The "theory" behind left tilt is so that the work piece won't get trapped between the blade and the fence when you are doing beveled cuts. The piece rides on "top" of the blade. With a right tilt the piece is "below" the blade and has a possibility of getting trapped. This is supposing you have the fence on the right side.
I know several people who use the Grizzly 1023 cabinet saws. They like them.
Plan ahead
Guy in Cuba
>For years I used a cheap table with a skill saw installed upside down in it. After buying a cabinet saw, I wondered why I hadn't bought one years ago. I now have a Grizzly 1023SL and really like it. I also had a Unisaw and enjoyed it too.
I put both on wheels, which gave me a lot of flexibility. About a year after buying the Grizzly, I installed a very handy, fold down, outfeed table, and now wish I had done that years ago too. Next I built sleds, tenoning, and miter jigs. Wondered why I hadn't done that earlier. Now I have a right hand table to install in which I intend to install a router. Already know that feature will be used a lot too.
Good luck.
Larry Clinton
>Kenny, you will probably find that most people are quite happy with the brand of cabinet saw they own. I have a USA made Delta Unisaw - left tilt, and am very happy with it. As has been stated the Right / left tilt has advocates on both sides. Left tilt advantage is that you can safely cut bevels in the normal ripping position (board to the left of the fence). Right tilt advantage is that the fence position indicator remains accurate when the blade thickness is changed or a dado blade installed. With a left tilt the arbor end is toward the fence so the left side of the blade is against the arbor shoulder and a thicker blade reduces the dimension to the fence, so you have to either compensate when setting your fence or realign the fence indicator. (hope that came out understandable). If you search the message archives, you will find many who have a Grizzly and are very happy. Same with Unisaw, General, Powermatic, Steel City and Jet. If I were in the market for a new saw I would also look at the Steel City line. They have some saws with a "TIN" coated table. They have a new cabinet saw with a Granite top. That sounds quite interesting to me as it would 100% prevent rust, remain 100% flat and the weight should reduce vibration. As to the Delta, I'm not sure I would buy one today. I looked at their offerings at a recent Woodworking show, I believe all their equipment is now Asian. If so, I certainly can't see paying a premium price for an Asian saw from an American manufacturer. None of the Delta equipment I looked at during the show (Cabinet saws, Band saws, jointers, planers) appear to be of the quality of the Grizzly, Jet, Steel City or other companies selling similar Asian offerings (normally at lower prices). Powermatic also has a new saw with a "riving knife" - this is a "splitter" that is located right behind the blade and rides up / down and angles with the blade. This is a big aid in preventing kickback. I don't know if the Powermatic is still made in USA - doubt it as it sure isn't mentioned in their homepage. Another TOP quality 100% Canadian made saw is the General (not to be confused with the General International - Asian made saw). Although pricey, it is regarded as one of the best saws on the market.
Re: Have you looked for a good used one?
Glenn Madsen near San Francisco
David Sparks
>I have a Powermatic 66 that I really like. At the time I bought it, I didn't have room for a 50" extension table and fence and got a 30" one instead. I've moved since then and now have plenty of room. If you can, try to get the longer extension table and fence.
knotscott
>Hi Kenny - I think it's a safe bet that any of the brands that have been mentioned should serve you well. In that price range, I really don't think there's a significant quality advantage of one over another, though things like warranty and a particular dealer can make you more comfortable. I think it's more important to get one that has the features and "feel" that you really like. I assume this is a once in a lifetime purchase, so a couple hundred bucks one way or the other won't mean much over the life of the saw. Look at them all, and go with the one that pegs your rev meter!
>Thanks a ton guys! This definately gives me some places to start. Im not familiar with the Steel City line at all. I noticed some at Woodcraft just this week, i'll have to go back and take a closer look for sure.
Steve Yakoban
>I know this is out of the price range but does anyone have any experience with the SawStop from a woodworking perspective?
Re: New table saw suggestions *LINK*
knotscott
>Hi Kenny - I don't own any Steel City brand tools either, but what I'm reading from owners is intriguing. They seem to be very good quality and have very good CS. One aspect I read frequently about their saws, is that they offer an upgraded Biese clone fence that glides more easily than others, which is something I'd want to check into.
Steel City was formed by former executives, product managers, and sales people from major machinery manufacturers, including Delta and WMH Tool Group (PM and Jet). Partners Scott Box and Mark Strahler are the movers and shakers of the group, who also owns Orion who designed and manufactures the Craftsman "zipcode" hybrids that are getting alot of good press. I do own one those hybrids and have been delighted with it.
Good luck!
SCTW
Jerry Nicholson
>I have never seen any Steel City equipment but I seem to recall that their headquarters is in Murfeesboro, about as "middle Tennessee" as you can get.
Jerry
Craftsman *LINK*
Charles Sharp
>Woodworking is my hobby, not my profession.
The Unisaws and Powermatics are great machines, however they are out of your price range.
Several years ago my wife bought me a Craftsman cabinet saw, their top of the line model with the Biesemeyer fence (now around $1,000). I've been VERY happy with it, no problems. It does have a minor short coming, you can't use much over a 3/4" dado stack because of the arbor length.
With your extra cash you can get yourself a dado set (6" works for me), some feather boards and material to make a panel sled and cross cut sled. After all that you still have enough cash left to make something.
Craftsman Table Saw
Re: Craftsman
Dan Mitchell
>I looked at that Craftsman when I bought my new PM. Looks like a lot of saw for the $$$. I see they have a $29 fence cradle that goes under the extension table. May get one for my saw!
Dan
Re: Craftsman
>Thanks for help everyone. I went with the Steel City 3 HP Table saw. Went a little over my budget, but I think it will be worth it in the long run. http://www.steelcitytoolworks.com/products_tools.cfm?section=2&category=12&tool=35621 Is a link to the saw I purchased.
Re: Congradulations - from everything I've
Larry Clinton
>read and heard, you have an excellent saw coming. Keep us apprised of your likes and dislikes, may help some other buyers. By the way, looking at the Rockler ad I received today, the picture of the Delta Unisaw had the "Made in USA" label on the lower left hand corner. Don't know if it still is made in Tennessee or if they are using old ad copy.
