THE WOODRAT IS BACK!
Whoo-Whee, do I have a Radial Arm Saw!
Gary Evans Tallassee, TN
>Hi all,
A few weeks ago, I bought a used 3HP, 3PH, 14" RAS by Dewalt. Over the ensuing period, I have bought a 3HP VFD off e-bay. Thanks to everyone who chipped in advice regarding a way to drive this bad boy.
Today I finally got it wired up and it kicked off and ran just like it is supposed to! Whoopee!
I spent more than a couple of hours squaring the arm with the fence and then squaring the blade to the fence. I don't know the accepted wisdom, but I clamped down a framing square to the fence, used a drill bit as a feeler guage and then kept adjusting the angle of the arm to the fence.
I got it down to where the rip only varies from square, .0025" over 16". I measured this by cutting a piece of 16" wide plywood, flipping it over to cut about 1/4" off the same edge on the opposite side of the blade and indexing the same edge to the fence. The piece I sawed off varied from end to end by .005". Since the error off-square is doubled by this method, my actual error looks to be .0025". I'm normally not that compulsive, so I figure I just got lucky. 8^}
Now all I need is a good 14" blade. I asked about this a couple of weeks ago and was told that a negative hook angle and an ATB grind is optimal for a RAS cutting primarily green wood.
It seems that the only 14" negative hook blades that I can find are triple-chip grind, designed for use with laminates. Does anyone have experience using a 3chip grind on a RAS? I don't need a glue-joint surface. I just need it to be relatively smooth, without burning. Of course, the other consideration is that I need this to be a combination blade, so that I can rip or crosscut as efficiently as possible. Doable or not?
Thanks,
Gary
Re: Whoo-Whee, do I have a Radial Arm Saw!
Like they say about harps
Neal in San Jose
>You spend 90 percent of your time tuning and 10 percent playing out of tune. I finally gave up on my radial arm as I wasn't able to keep it accurate enough for anything but very rough cross cuts. Every time I made an angled cut, taking it back to 90 degrees required full-on recalibration. PITA! However, I will say that a negative rake blade made a huge improvement in the saw's tendency to self feed (nice way to say it stopped trying to cut off important parts of my body!). I worked for a lumber yard for a while where we used a 17 inch RAS, and had no trouble buying blades thru the local sharpening shop we used. I can't immagine 14 inchers would be any harder to find that 17s. Try your local sharpening service or check with some pros.
Mike Baker
>I have a DeWalt 7790, and a DeWalt model 1200.
After a complete rebuild, new table and adustments three yrs ago,,
I yet to have to Tune or re-adjust anything!
The old Dewalts are great saws, and kill the sterotype of constantly havin to adjust a radial arm saw!
I would give up my first born before I let my saws go!:):)
Mike
RAS sawblades........
R. Lance in GR, Michigan
>just looked in a recent Delta tool catalog and they have 14" blades with -6* hook and 1" arbor holes available...I'm not recommending these blades one way or the other...just that they are available and I don't think you will have any problem finding blades for your saw from a number of companies...good luck.
Dale Lenz
Dale Lenz
>Congrads on the new toy, Gary. Seen a few 14" blades on ebay, cheaper blades probably.
Enjoy and be safe
Please! Forget about ripping with a RAS.
Keith Newton
>I don't care for the TC grind as much as ATB for my use, and I don't think it is necessary to go 10� negative to avoid climbing. I run a 10� positive on my 16". The only time I have ever felt any tendency to climb was when cutting thick stock which was bowed up, causing the kerf to close as the work settled near the end of the cut. This would still happen regardless of the hook angle.
The more negative the hook angle, the more power needed to do the same work.
As for using a RAS for ripping. Forget it. You need to get another saw for your ripping needs. It can be done alright, but there are just too many things making it very dangerous, and when you are in the middle of a situation, and maybe can see that things are going badly, you are stuck, there is just no easy way out.
I don't have enough time to describe all of the bad situations that can get you into trouble, because they are many. I think there should be a law against advertising radial saws as even being capable of ripping.
Couldn't disagree more.
Rod Peterson -- Ormond Beach, FL
>Nothing has aggravated me more since I discovered woodworking on the internet than constantly hearing the negative hyperbole about ripping on the RAS. I couldn't understand it all at first, having been a RAS owner since the early '70s. But after sifting through one batch of nonsense after another I finally reached the conclusion that, contrary to my eminently satisfactory (and safe) experience with ripping, the detractors generally could be sorted into two groups: those who had misused the saw and related their (not surprising) horrific experiences, and those who had read of the first and perpetuated the myth.
What misuse? Apparently some misguided tyros with little machine experience of any kind decided that since they didn't like the idea of the teeth coming towards them when ripping (just as they do on a table saw, by the way) they ripped from the opposite direction! It should be obvious to the most casual observer that experience derived from that misuse can't possibly be subtle or positive. Sadly, their proficiency at reporting their results was far more advanced than their ability to use machine tools.
The rest is simply propagation. Take any remotely plausible story and put it on the internet and the next thing you know, you have exploding dust collection systems, quality tools from Harbor Freight, and dangerous radial arm saws.
Now having said that, I know from experience that there are some people who just shouldn't be using machinery—maybe even plain old sharp tools. Sadly, that ineptitude doesn't prevent them from reporting or reproducing. Since you can't tell which type you're reading about you have to take anything you read on the internet (including this post) with a large grain of salt.
Radial arm saws unsafe? Harrumph!
Rod
Well stated Rod!
Ron Jones
>I couldn't agree more. A well tuned and maintained RAS is a pleasure to use.
Re: Couldn't disagree more.
JohnKJordan in East TN
I can't imagine anyone doing that, at least not more than once. Would not the blade immediately bind and stop the saw?
I always thought the problem was people feeding wood without using the proper hold-downs and riving knife. They get away with it sometimes for years before the accident. The wood binds slightly in the kerf, lifts, and is slammed back and/or pulls the hand up. Other emergency room scenarios are ripping short stock and failure to use a push stick.
I'm one who has ripped with the RAS for 35 years but I always use the properly adjusted hold-downs on the saw and featherboards where appropriate.
2nd that!
Pat Evans
>My RAS is mounted in a 9' bench with a 9' fence. It makes for safer and easier handling while ripping long boards.
A question
Dan Donaldson
>How is the splitter set up when ripping with a RAS?
Re: A question
It varies from saw to saw. Shoot, in the years I paid attention to Sears' (I have a 1971 version) I must have seen close to a dozen variations. Basically, there's a rod attached to the hood that is adjustable for height and the splitter and pawls are attached to the end of it. It has to be adjustable to accommodate different thicknesses of wood (and different carriage heights). I'll try to get a couple of snaps of mine in the next day or two and post them.
I don't dispute the value of a splitter and/or anti-kickback pawls but how many folks who run their tablesaw without the guard nevertheless fit a splitter when ripping? In any event, I maintain that kickback on a RAS is no more likely than it is on a tablesaw. I do recall, however having a very lively debate on that subject back on the Pond several years ago.
Rod
Re: A question
Dan Donaldson
>I was just wondering. I will plead guilty on not using the guard on my unisaw, but I have a drop in splitter that always gets used for any kind of ripping operation. I leave it in all of the time except when using the sled or dado.
Re: Have to agree Rod.
Larry Clinton
>Although I was guilty of feeding my saw from the wrong end in a moment of stupidity, (I DID know better - tired, finishing up a job, just didn't think). I was still in no danger, just woke me up and destroyed a board. I soon realized I had erred when the board became a missile that put a deep dent in some plywood about 20' away. Never the less I have fed many feet of material through the RAS, both rip and crosscut without incident. I really liked the fact I could cut accurate dado's across wide material (with my saw took some setup though). I think those that have problems with the RAS are the same ones that will crosscut a board on a TS without using a miter gage and blame the saw. I don't use my RAS in the shop any more - only because it is a cheap Royobi that didn't hold the settings well. I did a lot of work on it before equipping my shop with my Unisaw, CMS and bandsaw. Mine is on the recall list (get $75 for sending the motor in), but am finishing up a siding job at my son's before I destroy it. We used a old (40's 50's model) top quality 3 phase Dewalt 12" RAS at my place of employment for over 30 years as the sole maintenance department wood saw - never had any accidents or problems. They ripped and crosscut tons of material.
Re: A question
>Things looked to be getting "lively" here too....
Lee Brubaker
>Any time I see postings on the forum telling the world how dangerous an RAS is & that ripping is a no no I gotta smile. I bought my little RAS new in 1958 (makes it older than most people posting here). Mine is a 1hp DeWalt manufactured by American Machine & Foundry before Black & Decker got their mitts on the line. I also at the time bought a book authored by a DeWalt demonstrator & covered the "how to" for the many operations that the saw can perform as well as proper maintenance procedures. I do not own a table saw. They scare me.
My saw stays in tune. I have had to tune it after every move ie: from Calgary to Vancouver to Toronto, to Oakville,Ont., to Vancouver, to Edmonton,AB, to an acreage outside of Edmonton & lastly back to it's present location in Edmonton. Movers are not delicate about handling machinery.
My saw has always been mounted with 7ft workbenches on both in-feed and out-feed sides of the saw.
Being a 1hp saw, I'm not interested in negative rake blades because I do not want to lose any of that hp even if only fractionally.
I have had ONE kickback in 49 years of use. The reason....ripping a board too short for the anti-kickback mounted at the rear of the blade guard. Stupid.However no personal damage because the board was caught by the blade guard which was in a nose down position for ripping.
I have replaced the table & fence ONCE in the 49 years of use.
I also mount an old Craftsman 1hp router on my RAS...try that with your table saw ! I also have a sabre saw attachment allowing me to make inside cuts such as is done with a jig saw.
I was given a CMS on a folding stand as a retirement gift. Imagine my surprise when that "screaming piece of crap" was not as convenient to use as my RAS. The CMS has spent it's life,for the last 10 years leaning against the shop wall outta the way.
In short, those posters warning others about how dangerous an RAS is
have never bought an operational book written by an expert & really do not understand the ins & outs of their machine, or they have never owned an RAS & are simply parroting what other equally uniformed people have to say.
Lee
Amen
Mike Fitterling
