Dining Table with Spaghetti Style *LINK*
HC Sakman
>Hi Everybody,
I've some interesting pieces cooking up in my kitchen, but I've got this piece that's worthy of posting.
It's like those "Italian" style tables, except it has no frosted glass top, instead 44"x 112" top w/ two 15" wide leaves, which are stored under the top. (see the "open" picture.) I think that's a great feature, since those leaves are always in the way of some closets. Synchronized steel hardware under the top was a special order from Hettich, Germany. It was $500 and waited for almost 4 months. It's the mother of all slides though. Motion is smooth and works very well. One person can easily open or close it by him/herself.
Top is veneered with beautifully consistent straight grained (quarter-sawn) wenge and zebra veneers. There's a 1/8" square cherry inlayed in between wenge & zebra. Sunstrate is 1" MDF Ultralight, doubled along the edges, 3" wide. As you may noticed already, miters are precisely located at the corners to an absolute geometrical perfection and grain running along the length of the table top, which is a masochistic way of doing this job. It has a very substantial feel. Edges are solid 1/8"+ thick wenge, top is veneered over the edging. Underneath, the thicker 4" wide edges are also veneered with wenge, but the center is NOT veneered. Instead I rolled dark glue just like latex paint and that was sufficient enough to stabilize the MDF, thus preventing any warpage. Main sections of the top have latches, but leaves have cam locks.
Base is only 28" wide and 58" long. All solid wenge. Feet are matching the top, wenge-cherry-zebra-wenge order. I think the most obvious feature of the base is the large bevels. I will soon post some construction details and some useful tips for the WC's "Shopshots".
Finish is painstakingly handrubbed varnish since my client is allergic to lacquer. Top has been sanded to 1000G and the sheen is great without being too shiny. Probably over 10 coats of finish.
At the end, clients were thrilled with the result and I was pleased myself.
Thanks,
Chico...
Sakman fine Woodworks
