Bookcase Cabinet Lighting
Alan Young
Alan Young
>I'm building a pair of bookcases. They will need a lighting system that will send light on the shelves and books but also hopefully "bounce" light outward to give a sort of "glow"...These will be painted white so that should help reflect light outward.
I found this set of lights and thought it would be just the thing.
But in opening the package there are warnings that say the bulb gets hot very quickly and to keep it away from materials that may burn....
So does that rule this out for place in the interior roof area of a bookcase?
Alan
Re: Bookcase Cabinet Lighting
Larry in NW Ohio
>Alan I`m assuming they are Halogen. I have 15 of them under a cabinent in the kitchen. They are in a space just big enough to put them in, about an 1". They do get very hot, but Ive had them on for 6-8 hours already many times and nothing as of yet happened. But one thingI just did was to take the cover lenseoff, it sure did some good. But for me it just might be dumb luck, but if you can have an open top I think they`ll be OK. Larry In Ohio
Eddie Pacheco, San Jose, Ca.
>I have lights like these, different style same brand, mounted under some cabinets and so far so good. The housing is also behind a valence panel with about 1/8" gap all around on the cutouts. I usually leave them on for 4 to 6 hrs. max. Actually the warning lable should read damn hot. They are hologen lamps.
John McGaw
>I have similar puck lights, 20W xenon in my case, under my upper kitchen cabinets and they are mighty hot. And sadly, my run-of-the-mill borg units are not very reliable because of the cheap materials used for the spring contacts so they seem to come and go randomly.
One thing you might want to look at, as I am, is LED under-cabinet lights. They are not cheap by any stretch of the imagination but they should be much cooler and have virtually unlimited life. A quick google search for "LED cabinet lights" turns up quite a few possibilities.
Re: Bookcase Cabinet Lighting *LINK*
Jim Dillon
>Alan,
I also have the 20 watt xenon (supposedly 10% lower heat output) lights under my kitchen cabinets, but they are in a thin-metal box. They do indeed get warm and are great in the winter for keeping the dishes warm above them through 3/4 inch plywood 8-). So far, no problems. For lighting inside a kitchen display cabinet and in a china cabinet, I've had luck with these puck lights from Rockler. They can be either flush-mounted (my choice) or surface-mounted and, for flush-mount, require that you drill a hole through the top of the cabinet/bookshelf - but that gives you good ventilation. I combined those with a touch-dimmer (3-position). But, they are expensive. Pegasus Associates (www.pegasusassociates.com) carries an extensive line of lighting as well.
Since you have already bought your lights, and they are expensive, you might just double-tape or screw them to a thin piece of wood/cardboard etc. and let them run for a few hours to see how hot they really get. Hope this helps.
Jim
Low Profile Xenon Light
Brian in Sandusky, OH
>I have those lights on a bookcase. See the link.
Look at my pics, and see how close my books and DVD's are.
Those lights do get hot, but I've kept the books at least 6 inches or so from lights and never had an issue...and I've kept a close eye on them wondering how hot they might get. The lights can be on as long as I wish...no issues....they are hot, it's a very local heat.
Just don't touch them!
By the way...go with a touch switch. Very cool and handy.
Bookcase
