Remote Indicator for Dust Collector
Steve MacLeod
>My dust collector is remote from my shop which is nice for sound and dust reduction. It has a 220V motor w/ a magnetic switch and I start it using a wireless remote sold by Woodcraft. The problem is I forget its on and often, hours after I've left the shop, my lovely bride will ask why the noisy thing is still turning. I tried wiring a 110V light to one leg of the wires after the remote switch but because of the magnetic start switch there is continuous voltage and the light remains on. The local electrical experts say there is no solution. I'd love to prove that wrong. I'm looking for vibration or noise sensors to send a signal that could turn the light on. Any other ideas?? Thanks for whatever suggestions you may have.
Re: Remote Indicator for Dust Collector
Dan Donaldson
>buy a 220 volt bulb and wire it across the motor. It will be lit when the motor is on and off otherwise. This bulb will not have a neutral, but will connect across the two hot leads. You could do the same thing by hooking two 120 volt lamps in series across the motor, but make sure they are the same type and wattage.
Also, watch the insulation. Most sockets are set up so that the outer shell is ground. Hooked to 220, the shell is hot also and needs to be well insulated.
Rob Hix - King George, VA
>You could get a current sensor that wraps around the outside of the DC power supply wire. When current flows through the wired, the sensor develops an output voltage. This voltage, in turn, could be used to operate a relay which would turn on and off a light bulb on a 120 circuit.
This description is probably a little over-simplified, but I am sure it could be made to work easily enough.
Rob Hix
>Look up Automatic Blast Gates or Automatically Turning on the Dust Collector or something along those lines.
There have been a couple of threads here about having the DC come one when you turn the tool on. IIRC they wire a coil into the circuit for the tool that senses current flow and it turns on the DC and if you have powered Blast gates opens the gate on the individual tool. I am not suggesting you go to that setup, unless you want to, but you could use one of the "sensor/switches" wired into the the DC circuit to turn on a light to remind you the DC is on. (Sort of takeing the remote switdh idea and standing it on it head) I am assuming you can get to the wiring for the DC. In my case, my electrical panel is in my shop, so it would be easy to put the coil/sensor in there, but all you need is access to the firing. You would have to separate the wires, the sensor would go around one 120 volt wire to the DC.
Whatever you do, use a very long lived bulb for an indicator. If the bulb gos out the DC will run forever or until you Sweetie notices.
How about a timer? If you never work after 10 (?) o'clock, turn it off every night at ten.
Or, how about some sort of universal switch that kills the power the whole shop when you leave? A good safety feature that means there is no power to anything.
Michael Wangler in Rochester, NY
>Steve,
I use a small $20 remote to turn on/off my Jet dust collector. It works well except that it will randomly turn on in the middle of the night and I would have to make my way into the basement to shut it down.
I put the dust control on it own switch. I put the switch in a double switch box that also contains a switch for the shop lights. I then put a small piece of wood across the light switch. This way I have to shut down the dust collector circuit every time I turn off the lights. I did not connect the wood to the dust collector switch. This way I can turn the lights on without turning the dust collector circuit on every time.
Good luck,
Michael
Larry in NW Ohio
>Steve Unless they changed magnetic switchs since I worked on them, it`s easy to come out of the switch and get 110. If you could send a picture it would be easier to explain. But here goes. On a 220 magnetic switch you have to hots, each 110 volts. when you look in the switch assy. you should see points that will make contact and disconnect as you push the on and the stop button. the contact you are interest in is the contact that is not making connection when it is off. Of course UNPLUG your saw first. There is a set of contacts that move back and forth as you hit the on-off buttons. You need to connect one wire to the nonconnect point and a nutral wire. I think to be safe I would put a 5 amp fuse inline of the light bulb. Your best bet if your uneasy about doing thid get someone who is not. You may want to use an ampmeter instead of a light bulb first. Of course I bare no responsibility for anything I say. This is how I have my Unisaw hooked up to open my blast gates Larry in Ohio
Pat Evans
>Can you get an auxiliary contact for your starter? Common on industrial starters, but I'm not sure about your DC starter.
Possible Passive Solution
Eddie Pacheco: San Jose, Ca.
>While the light bulb ideas are good, you will need to run wiring from your dust collector to your shop to place the bulb where you can see it. If you can add a dummy leg to the duct work and dead end it with something like a diaphram or vane that will suck in or move when the blower is on. A quick glance and you'll see that your blower is still running.
Angus Barclay, in New Zealand
>Hello Steve,
The local electrical experts who say there is no solution lack imagination. They don't have a good attitude towards problem solving. Your DC is drawing current, moving air, making noise, and generating pressure - so there are many ways you can set up mechanical or electrical devices to sense and indicate that current draw, air movement, noise, or pressure.
An air bleed tube from the main duct run connected to the top of a vertical transparent pipe containing a small foam ball or film canister could work. If there is suction, then the ball or canister will be rise up the transparent tube. If there is no air movement (i.e. DC is switched off) then the ball or canister will fall to the bottom.
Go to a pet store and buy something like this cheap device. Put the ball or canister in it, put a screw, bolt, nail, or dowel through the open end to stop the ball or canister falling out, mount the tube vertically near the duct and with the open end down, drill a hole into the top of the duct and poke the end of the hose into it, tape or caulk the hose connection and you're done.
The best option is usually the simplest and sometimes is even cheap and easy to do!
regards
Angus Barclay
Steve MacLeod
>WOW! Thanks to all you creative folks. I had been fixated on the light idea and couldn't see the other options, nor the new ideas about the light. Thanks for taking time to offer your suggestions. Steve
