Corian or equivalent conter tops
Bill Tindall, E.TN
>Wife is interested in replacing worn Formica counter tops with Corian or equivalent. Any advice for the WC experts? I am annoyed that I apparently can't buy the stuff and do it myself, but other than that......
Re: Corian or equivalent conter tops
Dan Manturi
>I have heard that there are online sources for Corian. Google it and I think you will find some. Yes, I agree, what is the reason why you cannot buy it at a home store or lumber yard?
That said, I sort of like laminate. Cheap. Versatile. Takes a beating. My stepson wanted granite or Corian, but given the price difference, i think we will stick with laminate.
Good luck.
Bruce, a MN Galoot
>Bill, My BIL in Fargo owns the first cabinet shop in ND certified to install corian. He said it has to do with the little bit of training the manufacturer gives having to do with gluing the edges, miters, backsplashes and finishing those joints. It's not difficult.
If you know someone who has a cabinet shop, they should be able to hook you up.
Bruce
M.Burns
>Take a look at concrete. Cheap, versatile, durable, and you can do it yourself. See www.concreteexchange.com.
Bart Castleberry
>concrete is cheaper if you make it yourself, but it's not especailly durable, is prone to staining and chipping. Still it can be really pretty and appropriate depending on your expectations and use.
granite is now cheaper here due to the price of oil which is used to make corian.
ted Wong
>I agree that concrete is not necessarily durable. But it's not cheap either when you factor in time. I've done several concrete pours and some of them were countertops. By the time you count the needed accessories, time needed to make the forms, tool rental, diamond discs for grinding, etc. it's a pricey alternative.
But this is not what this threead is about to answer the question there are a few places online that sell solid surface material cut to order allowing the DIY'er to install.
Re: Corian or equivalent conter tops *LINK*
Dan Manturi
>I googled Corian and Do it yourself. This is the place I foun d last time (URL attached). There may be others too.
Dan M.
http://www.solid-surface-kits.com/
Jim Dillon
>Morning Bill,
It is a shame that Corian isn't widely available as it works just like wood, but the router shavings are something to behold due to electrostatic interaction. I cut the sink hole for a vanity top and found that the stuff cuts like butter. And I watched our Corian countertop installer glue two 24 inch wide pieces together and it was easy (well, easy for him). He used a Sawsall(!) to cut the countertop apart (I couldn't watch), clamped a scrap edge of wood parallel to the rough edge, then smoothed edges with an old PC 7518 router and flush trim bit. He then used hot-glue to glue a couple of 2x2 inch blocks of wood on either side of the seam, applied the glue and clamped for 10 minutes or so. Then just popped off the hot-glued blockes with a chisel. He sanded the seam with a PC ROS using Abatron sanding discs to 4000 grit.
Anyway, I digress. Here is a link to a place that sells Corian. The largest piece they sell is 15 x 72 inches. Another link is http://www.naturalhandyman.com/iip/infcountertop/infsolidsurface.html
where I see they reference the link that Dan suggested.
For solid surface tools, try http://www.specialtytools.com.
I think the original issues with Corian had to do with installing the countertop to the top of the cabinet. Corian expands and contracts just like wood so installers now use a few dabs of silicone adhesive at the corners. Plus this makes it easy to remove if necessary.
While we like our Corian countertops very much, there are really a lot of options available - most, unfortunately, rather expensive. Laminate is still the best value IMOH. Hope this helps.
Jim
Corian for the Creative
matt overton
>Bill,
We put corian in our kitchen when we remodelled our whole house. It is a good surface, but not perfect by any means. It is softer than I expected. After 3 years it could use a buffing out (not difficult if you can get the right abrasive sheets. It gets small scratches fairly easily. If you can stomach the price, it is as good as anything out there in my opinion. our kitchen had 40 lin ft, you can see why the price bothers me. All in all, go for it, just make sure your wife sees the color she wants in a sample counter, not just the sample squares. Good luck
Matt
Mike72903
>My wife wanted and got corian in the 'silt' color. We've had it several months now and like a previous poster says it does scratch pretty easily. If you scrub it hard with a green scruffy it will leave scratches that will show in the right light. Absolutely cannot cut on it ever. The reason my wife wanted it was because of the built in seamless sink which is nice. No rim or anything to collect stuff or leak. In our area it was priced about the same as granite. It is much warmer than granite and most other hard surfaces. All in all I guess I'm okay with it
Steve Schoene
>The fact that Corian is priced about the same as granite should lead to a mass exodus to granite. And, I think it is, in part because granite is a very material with much greater longevity and resistance to heat. And, if it matters, granite counters will retain a much larger percentage of their cost when a house is sold than will Corian. Besides I think most granite looks better.
Larry in NW Ohio
>We put silestone a little over a year ago and really like it. You can set a hot pan on it right from the stove and it doesn`t scratch. GOOD STUFF Larry in ohio
ohio
Steve Kreitler
>You could always scrounge it. I've been collecting drops from a corian counter shop for years to make things from. If I can ever find the time, I'm planning to do our bathroom floors in a random pattern with 2" squares of the stuff- or our counter tops, whichever I manage to get to first.
Some shops toss their drops (large scraps), but since it's so expensive, some shops hang onto it, if they have the room. If you can locate one of the latter shops, you might be able to pick up a large quantity at a fairly reasonable price. Of course, if your wife requires a specific kind/color, you're outta luck on that one.
Corian isn't hard to work- regular carbide woodworking tools will work just fine on it- you have to use a much slower feed speed, though. It will definitely dull your tools, so I would recomend not using your best cutters on it. In fact, in my tablesaw, I've had the best luck using an old skilsaw blade- it seems to clear the chips much better than a 40 tooth combi blade (which can carry chips all the way around, and make gouges in the kerf). This also makes it impossible to mix up my corian blade and my good wood blades.
Oh, and it can be cut and inlayed on the scrollsaw, as well, with some practice. I've made a number of belt buckles with inlaid initials from the stuff. Again, slow the feed and cutting speed, and use a bigger blade than you would for wood- otherwise the chips won't fall out, and will just melt in the cut. Oh, and one other thing- no reverse tooth blades for corian!
I guess that what I'm getting at here is that you could do a mosaic or inlayed pattern with corian, and exercise your creativity- if your wife will go for it :) Myself, I've got a big piece of purple corian sitting here by my desk (the guy at the shop said "take it- we'll never do anything with it"). Now I just have to figure out what to do with it in order to please my purple-loving wife!
I'll second that
Ken Garlock, Collin County Texas
>We put Silestone in our kitchen when we built in 2002. It looks as good as new. It does not stain. Just a wet cloth cleans up anything.
We found out who the Expo-Borg used, and bought directly from that supplier for a savings of $10/sq ft.
Happy saw dust,
Ken, who just got a new E-class Bluetec diesel.
On its way out!
Jack
>Hi Bill
In the residential world, I think SS has run out of steam. I run a cabinet shop in Mississippi and haven't sold a SS job to a residential customer in over two years. Anyone with the bucks to pay for Corian (DuPont)or Gibraltar (Wilsonart) buys granite or better yet, quartz. Around here, granite is a LOT cheaper than SS.
Commercial applications are a different story. Almost all doctors offices and hospitals are replacing high pressure laminate work surfaces with solid surface. For them, it wears better, doesn't get as beat up looking and meets the infection control criteria they have to live by.
If it were me, I'd opt for granite myself. I think it's a better investment. Granite is timeless and tends to appeal to the masses better than the 'plastic' look of SS.
Good luck
Jack
