wiping varnish recipe
yarg
>Has anyone tried the recipe for making a wiping varnish described on freds corner?
yarg
Re: wiping varnish recipe
Lee Brubaker
>Dunno about "Fred's" receipe but I make my own by mixing naptha with varnish with the naptha comprising 30% by volume. Usually wipe on up to 5 coats with sanding between coats using 400 wet/dry sandpaper.
If the coat is dry, a white powder will accumulate on the sandpaper, if not dry enough you get little gumballs on the paper.
Clear varnish will give a glossy glasslike finish. I usually use semi-gloss varnish.
Lee
Ray Binnicker
>Don't know about the one on Fred's corner but I've been using the one mentioned in Sam Maloof's book "Woodworker" for a number of years and like it a lot. It is 1/3 boiled linseed oil, 1/3 raw tung oil and 1/3 urethane varnish. Sam also lists another finish that I've tried and like also. It consists of 1/2 boilded linseed oil and 1/2 raw tung oil heated in a double boiler to which is added a handful of shreded beeswax. It comes out with the consistency of a very heavy cream.
Ray Binnicker
Re: Don't use your wife's double boiler though..
>or else you may end up buying her a new one (DAMHIKT). That's a good recipe I'll have to try. I've been mixing my own wax (1/2 carnuba and 1/2 beeswax) for a while, but I hadn't thought of making a "cream" finish.
Re: That's what I use, too.
Glenn Madsen near San Francisco
Steve Schoene
>Just remember, when you mix oil and varnish you have an oil/varnish mix, not wiping varnish. The differance is important, since with the oil/varnish you want to wipe off all finish remaining on the surface after a short "penetration" period. Oil/varnish mixes are relatively soft and shouldn't be allowed to build a film on the surface.
Thinning a varnish most just changes how it is applied. After the extra solvent evaporates it cures like regular varnish. If the cure is faster it is likely because the coat is thinner. This can be used to build a more protective film, though it takes a lot more coats than when using "high test" brush on varnish.
Re: The thing about wiping varnish
>I do modest sized projects. Nothing larger than a kitchen or a bathroom, and usually smaller. And then, they mostly are done in parts. So when it's finishing time, I don't have a huge project to do at any one time. Coating a king-sized headboard, for example, may take 10 minutes.
With a wiping product, it's do a coat, let it cure, dry and throw away the wiper. With a brush, I use more finish material just coating the cup than I do on the piece. And cleaning the brush takes longer than applying the finish. So either I do fewer passes than I should, or I wipe/pad it on. Fits my style.
Were I not a hobby guy, fitting this in around the rest of life, the other methods might be better. I'm not likely to find out from personal experience.
Wiping Varnish vs Oil/varnish Mixture
Howard Acheson
>There are two "brews" frequently referred to as "wiping varnish". In truth, wiping varnish is a thinned varnish that is wiped on with a rag. It is made by mixing your favorite varnish or poly varnish about 50/50 with mineral spirits or naphtha. The 50/50 is somewhat arbitrary and you can vary it to suit your needs.
The second "brew" is the oil/varnish mixture(ala Watco, Minwax Tung Oil Finish, Danish Oil, etc.) This brew is generally made by mixing equal parts of your favorite varnish, boiled linseed oil and mineral spirits. It is either wiped on or brushed on and then wiped dry after about 15 minutes. It's and "in-the-wood" finish but it not as durable as the thinned varnish.
There are some who use full strength varnish and just wipe it one and then wipe it off. This is sort of what David Marks calls his "Tung Oil" which is just General Finishes Arm-R-Seal. Not tung oil at all.
