Veritas - Innovation in Tools
Wooden Garage Doors
Wooden Garage Doors
Wooden Garage Doors
joey basile
>Can I remove my 4 aluminum panel, garage door segments and replace them with wooden one's that I make? Thanks Joey
Re: Wooden Garage Doors
Simon St.Laurent - Dryden, NY
>I have a wooden overhead garage door, apparently the original from my house's 1929 construction. (It fits a Model T well, probably, but modern cars are too wide. A Miata barely fit.)
A spring broke a few years ago and it sounded like a thunderstorm down there for a bit. The repairman was amazed to see the door, and said something like "it's a good thing I was carrying the heavy springs".
So I'd guess you could do it, but you'd need to check into the springs and other engineering questions. Or you could build them very light, though I think it'd be hard to compete with aluminum.
Sawdust Everywhere
>you surely can.
But you have to change the springs to counter balance the additional weight of the wooden doors in comparison to the alum doors.
Other than that, you should not need to change anyhting else. Rollers and track should be the same if your current door is well aligned and balanced. If you have a garage door opener, you should get a 1/2 hp if you have a double size door.
John in New Mexico
>In addition to the other guys' advice about heavy springs and hardware, I'd suggest western red cedar as a possible wood. Its pretty rot resistent, takes paint well, and is nice and light. Post some pictures if you build it, we don't get to see that sort of project often!
John
>I would have said No, well maybe.
The springs will have to be changed.
I doubt the rollers and hardware will have the right spacing to work on a wooden door. The track is not verticle. It leans in slightly and he rollers are sequenced so that the door decends vertically but move toward the opening. I doubt the brackets for the wheels will fit as they need to on a wooden door due to the differences in the thickness.
Check and recheck carefully.
DB
>Yes you can BUT you will have to replace the springs and hinges. Most likely you will want to replace the track with heavier gauge track. The rollers will probably work but they are probably the cheapest ones availble and wont last to long, better replace those also. All of the above info really depends on what your exact design of your door is going to be.
I can thyink of one design that will not add to much weight, but that would look like junk so why bother something else.
In case you are wondering I am currently working at a large garage door manufacturing company.
I have one
Charles Sharp
>I had one put up around 20 years ago.
Mine faces south so it gets full sun and creates finishing headaches.
The best finish I have found is Thompsons Advance. Everything else cracked and peeled off. I sprayed it on with a garden sprayer and brushed it out where needed.
On the inside of each section is a steel piece that goes from one side of the door to the other and supports the door sections when the door is up. It's kind of a "U" shape with a flange on the legs to put the screws through.
Also put some VERY Heavy weather stripping material on the bottom edge to keep water out, absorb shock when closing and keep the bottom off of the ground.
There is also a shallow lap joint on the top rail of one section and the bottom rail of the section above to keep water out.
Re: I have one
DB
>Charles
I will bet that is a double wide door. That is why you have the metal struts on that door. Helps prevent sagging on the wider doors.
