Drill Press
Drill Press
Drill Press
Norm Thomas
>I just picked up a Craftsman drill press at an auction. It is an older one with 8 speeds, 380rpm to 8,500rpm! Why did they make them go so fast? Today's drill press have a top speed of around 3,000rpm! Don't know just how old this one is but the table does not have a crank. The model # is 113-213710. It works fine & I bought it for my Daughter who is setting up a shop. I have an AMT in my shop with 12 speeds from 250rpm to 3,100rpm. Thanks, Norm Thomas, Camillus,NY
Re: Drill Press
Re: Drill Press
>Are those the speeds marked on the Drill press. It could be it has a 3450 motor instead of 1725. Just a guess on my part.
Re: Drill Press
Re: Drill Press
RobV
>The high speed was so it could be used as a shaper. I saw an old (late 60's) Delta variable speed that went from 200 to 12,500.
Re: Drill Press
Sounds suspiciously like…
Rod Peterson -- Ormond Beach
>…my old drill press. Here's a picture of it:
It had two 8-step pulleys and a 3⁄16" V-belt—no idler pulley(s).
One time I was demonstrating to a friend the 8550 speed on the thing, not thinking about the fact that I had a fairly dense 3" sanding drum in the chuck. It took a second or two to wind up to 8550, but before it got to it, there was a loud “bang!” and the sanding drum flew across the room and the drill press started shaking like mad.
I got it shut off, only to find a destroyed chuck (not so readily apparent, but when I tried to run the jaws it wouldn't work) and a severely bent spindle. My friend found great amusement for years afterwards in my telling him to wait there while I went upstairs to change my shorts.
Cost me a new spindle and a new chuck.
It wasn't too bad a drill press for what I was doing, but not having a crank up table was a huge inconvenience. It did have, however, one feature that was missing on higher end drill presses for many years—a quill lock. I don't know how folks got along without them. It was a go/no go item years later when I went drill press shopping. My Delta 17-925 has one. I still don't know how folks got along without them.
Rod
Re: Drill Press
Re: Sounds suspiciously like�
Larry in NW Ohio
>Rod-Norm I have one just like that but the # on mine is 113.213780 and I have a quill lock, must be a later model. I really like mine, I think these were some of the last ones they sold that were still made in the states. Larry in Ohio
Re: Drill Press
Norm Thomas
>Rod,Larry, glad to hear from you on the drill press! I painted the 2 groves in the pully for the top 2 speeds "red"! I am going to instruct my Daughter not to use thrm! Also painted out the instuctions for these 2 speeds that are posted on the side of the press. The run out on this press is excessive, .014 at the chuck! The problem is in the chuck and I will keep my eye open for another. I go to all the local flea markets. It is a Jacobs threaded for 1 inch! A strange size! Meanwhile it is usable! I drilled both wood and metal and it worked fine! A little more vibration when the bit breaks through but that is to be exspected. I only paid $100 for it and it came with a cross vise! I also had to pay a young man $10 to help me carry it to my truck! It's a heavy sucker! I still haven't figured out why the high speeds? I don't think it was so it could be used as a shaper as the instructions on the side give drilling specks for all the speeds? Thanks, Norm
Re: Drill Press
As I recall…
>…the chuck on mine had a #33 Jacobs taper, although unlike many other drill presses, it didn't rely solely on the taper for attachment—there was a threaded ring on the spindle and a collar on the chuck which threaded onto the ring and pulled the taper tight. I also had a an attachment with the same collar, and I'm struggling right now to remember what it was for. I have a sneaking suspicion it was a ½" spindle for…you guessed it—shaper cutters.
They also sold a router bit collet which fit on that ½" spindle, and which I had as well. The 8550 wasn't fast enough for routing, so once I had tried it, I never bothered with it again.
Rod
Re: Drill Press
Re: As I recall�
Norm Thomas
>Rod, I was al;l wet on that chuck! It is a Jacob's #33 taper & it has a ring over it threaded on the 1 inch spindle. I don't quite understand the collet attached to the chuck. I suppose it would make sense if I took it apart? I guess I need to look for a Jacob's #33 taper? It will be a little easier! I can't imagine using a drill press for a shaper but I used to use my Shopsmith for one! Thanks forthe help, Norm
Re: Drill Press
Separate attachment.
>The collet wasn't attached to the chuck. The ½" spindle attachment replaced the chuck (considerably reducing the mass on the end of the spindle, by the way) and the collet screwed onto that spindle.
At least that's how I remember it. Although I only sold the drill press a couple of years ago, in truth, I hadn't used it since I cleaned out the old shop in '99.
Rod
