Beadboard Ceiling
Beadboard Ceiling
Beadboard Ceiling
Rod Rentz
>I've seen some beadboard ceilings and really liked them. Are they difficult to install? Any tips?
Re: Beadboard Ceiling
Joe Shelton
>Tedious, but not difficult. A pin nailer is very nice for the light stuff.
Do not prime it before you install it. DAMHIKT.
JS
>I aggree with the pin nailer, but if you are putting this up on a porch exposed to the weather you might want to hunt down some galvanized or stainless steel pins. I have soem SS ones I hoard for my outdoor projects. Really ticks me off to finish a project and see the nails rusting and bleeding through.
Ernie Miller
>I'm getting ready to install one in the sun room I am building if you wait a few days I can show you step by step pictures. I and putting a clear varnish on the boards tonight they will need to dry good befor a second coat and then the will get put up maybe this weekend. I'll take lots of pictures
Prepriming?
Dave Bair, Eaton Rapids, MI
>I just installed beadboard on a wall. I preprimed and prepainted without any issues. Are ceilings a different critter? Painting a ceiling is a pain as it is, I'd hate to try to get paint into the grooves from below.
wes bischel
>Rod,
It is a bit time consuming, but once you get a rhythm going, it's easy. I pre-primed front and back before installation - BUT - make sure you tint the primer close to your finish coat otherwise white stripes will show when the wood moves. I've done both interior and exterior installations without problems. One nice thing about plank ceilings is typically there is very little waste.
Wes
Rod Rentz
>It's an interior project and I'll be attaching it directly to the trusses (24" centers). The only instructions I've seen call for 2" nails, but it seems that my 1 1/2" brad nailer would suffice. I could rent a larger nail gun.
Re: "directly to the trusses "
>Without a backer of some sort, the board will likely sag between joists @ 24".
ernie miller
>I installed my celing this weekend I agree at 24" centers you will probably have come sag I used the 3/8" boards from the borg it went up easy I used 1 1/4" brads in my air gun it called for 1" make sure that the first row goes yp straight! then keep the rows straight. first picture is Megan varnishing it befor it is installed
ernie miller
>this is a picture of the celing as it went up. there is insulation above it is on 16" centers
ernie miller
>This is what it looks like finished I still have 8 rows to go but it needs varnished first two coats is what I put on. about 5 hours to hang a 16X14 room
John Veerkamp
>Looks good Ernie, I like it.
John
Mike Fitterling
>Looks good, Ernie! I am about to do the same thing to our back sleeping porch. Just put the insulation in on Saturday. I am using 3/4" pine. I don't expect any sag, at least from that thickness, as all our ceilings are tongue and groove heart-pine 3/4" throughout the rest of the house and there is no sag anywhere and most of it has been up since 1914. I doubt you'll have any problems with yours.
Cheers,
Mike
Re: Fire and wood ceilings
Dave Mount
>Whenever a construction thread gets going, there's always someone chiming in about codes. Never thought it would be me, but. . .
Where I live, there are no building code requirements other than for electrical, and I'm not trying to tell anyone what they should or shouldn't do. However, as a point of information for those contemplating a wood ceiling like those discussed in this thread, I believe building codes in most locales would frown on installing wood paneling directly over the framing. The concern is the ease with which fire could spread through the ceiling and into the attic and/or upper floor. I believe the code-friendly approach is to install 5/8" sheetrock over the framing, then put the paneling over that. This provides some fire resistance to the ceiling.
You can still nail the paneling into the trusses, but you need longer nails. I use a 16 g 2.5" brad blind nailed through the tongue. You need surpisingly long fasteners; nailed on a 45 degree angle, it is about 1.6" just to reach through from the surface of the tongue of 3/4" paneling down through 5/8" of drywall to the *surface* of the framing. Whatever length you have beyond that goes into the framing. A 2" brad would put only about 3/8" into the framing, which is why I use 2.5" brads. Construction adhesive can be used to supplement the fastening; I typically glue every third course, though that's probably overkill (and will undoubtedly cause some cussing from whoever takes it down. . .hope that's not me).
Best,
Dave
A good precaution, but not sure its a code thing..
John in New Mexico
>Which I only mention because one of my neighbors put in wood ceilings when building a couple years ago. No problems from the inspector, and they follow the IRC pretty closely here. Now in comercial buildings I've heard that it is a big deal (from a friend who was remodeling a restaraunt), due to higher occupancy and such.
John
Not Code Here
Mike Fitterling
>After Hurricane Charley ruined the ceilings in our livingroom and hall, we had replacement wood ceilings matching the old put in. All was done under permit. Of course, it was not new construction; that could be different fro all I know.
This old house is almost all heart-pine (think lighter-knot), so if it ever caught I don't think there would be much of a chance of stopping it anyway.
Old or new, no difference...
John in New Mexico
>In my limited experience, code authorities require remodeling and repair work to meet current code rather than the existing code when the structure was built. They will allow variances when there is a compelling reason to do so, such as historical accuracy - like someone wanting knob and tube wiring in their historic building (I've never heard of anyone wanting this, but there is a provision here in NM to allow it under certain circumstances, it may be the same in other states as well).
John
Where Code does come it....
Steve Schoene
>Where the Code comes in may depend on the kind of insulation above the ceiling. If it is foam plastic, then section R314 of IRC 2003 requires 1/2" gypsum (or the thermal equivalent) between the foam and the interior of the building. There are also general flame spread limitations for wall and ceiling finishes in R315, but from what my quick look around the web indicates, wood bead board ought to meet that requirement easily.
