OT: Home Plumbing
OT: Home Plumbing
OT: Home Plumbing
Mark Kauder, Phenix City, AL
>I have a toilet in the master bathroom that almost never completely empties the contents when flushed. It has been that way since we moved in 12 years ago (ok, yeah that is procrastination). Until my wifes passing last year, this was primarily her bathroom, so I seldom was reminded of the problem. I was using the other main bathroom (I liked that shower better).
Anyway, I do not have similar outflow problems anywhere else in the house. The toilet inself is exactly the same as in the other bathroom. Both are 30 yr old (or so) American Standard toilets, in good shape.
The outflow appears good when flushed.
Ideas?
Mark
Re: OT: Home Plumbing
Al Stokka - Cambridge, Iowa
>Since you have two identical toiles, this should be a piece of cake.
Check the water level in the tanks. I hoping the level in the not-flush-so-good toilet is lower. Raise (bend up) the float rod and your problem (actually, the toilet's problem) will be over...
I hope.
Al
Kevin Mac Luskie
>Check for calcium build up that often times will block the little holes under the rim. (it would be odd to only affect one toilet, and not the other, but worth checking) if there is reduced flow through those holes, it will affect flushing.
Bill White
>Go get one of the new FLUIDMASTER units and a new flapper. You can fix it like new for $20.00.
No connection etc., blah, blah.
Bill
Loftguy
>Hi,
If this toilet has a seperate vent stack, check to be sure it isn't partially blocked. Had an instance recently where the test cover hadn't been removed from the stack after final inspection.
Bob
>Good suggestions here, Check them out.
Another thing to check is the water level in the bowl(s).
If the toilet that flushes poorly has a lower level of water in the bowl that may be the problem.
The little tube that pees down the center tube refills the bowl. (It looks like water is going down the drain, but most of it refills the bowl) Some people move the tube to pee in the tanks thinking they are saving the water. Then, the bowl does not refill to the proper level and you get the "good flush/bad flush" deal. The bad flush does a poor job, but leaves the bowl full. Then the good flush does a good job, but empties the bowl, sttting you up for the next bad flush.
If the refill tube is peeing down the overflow as it should be check to see if it is pinched or otherwise restricted.
John McGaw
>On occasion problems such as you describe can be caused by a partial blockage in the 4" pipe. Sometimes something a simple as a mis-squished wax ring can be the culprit.
>Nah, both exactly the same fill level, with the same flush system inside.
Tks.
Mark
Jim Dillon
>Mark,
Check that the little chain connecting the inside lever-arm to the flapper is adjusted properly so that the flapper is pulled fully open when you flush (but not so far open that the flapper stays open). If the flapper is not fully opening, then you won't get a decent flush, yet the tank water levels between your two toilets would be the same. Usually you can adjust the chain length easily. Also, it is possible that the inside lever-arm, over the years, has pivoted a bit in the connection to the outside lever-handle leading, again, to flapper problems. Just some thoughts.
Jim
Larry in NW Ohio
>Mark One thing that hasn`t been mentioned yet is the little hole, about the size of a nichel, down in the bowl. You can see it if you look from the seat side. I had that plug one time and gave me bad flushes. So make sure that is not pluged, I still don`t know what it is for. Good luck and you have a lot of excellent suggestions. Larry in Ohio
Eat more Fiber.
Re: Eeeeeeeeeewwwwww ;^)
Howard
>That may be the problem. I get calcium build up the partially closes this hole and it effects the flushing.
I got a wire brush used for cleaning copper tubing fittings and use it to clean out this hole and toilet operates like new.
Howard
DB
>Something could be blocking the bends in the toilet itself. I have found various objects stuck in the bend such as the metal wire from the toilet bowl cleaner that hangs over the edge of the bowl, bus passes, even eyeglasses.
Remove all of the water from the bowl and using an inspection mirror and flashlight look up the passage way. You may just see what is blocking the toilet.
If you do not see anything and all of the other suggestions do not help then remove the toilet and look up the outlet with the mirror and flashlight.
If you do see something then you will have to remove it. One way that might work is with mechanical fingers. If that does not work then take the toilet outside and put the garden hose (no nozzle) into the outlet as far as possible and turn the water on full while blocking the rest of the outlet with your hand or a rag. Most likely this will remove anything that is causing the problem.
BINGO ! ! ! . . .
s.mackay@worldnet.att.net
>These are worth three times the cost ! ! ! And . . . while your in the toilet section get a couple " korky " flappers. Also wirth thier weight in gold ! I had the same problem in one bath so retro-fitted BOTH baths. Problem solved and headed it off in the second. One of the BEST fifty bucks I've spent on the house !
>Lots of good things to check out.
Thank you all for your help.
Mark
