Re: Dust Collector Filter
Jim Dillon
>Ken,
I also have the Oneida internal filter cartridge and clean it every 3 months or so. It is a NASTY job. Be sure to wear a good dust mask and pick a non-windy day! I very carefully remove the filter trying not to dislodge any of that really fine dust that is caked on, place the filter in a garbage bag, and tap it several times to get most of the major stuff off. Then I go outside and use an air compressor to blow the remainder off. I think Oneida recommends blowing only in the direction that the air normally flows through the filter, i.e. outside to inside - but I've also blown from the inside as well with no apparent effects. As filter materials can differ, it might be worth a call to the manufacturer to see what they recommend. Hope this helps.
Jim
