Basement shp/dehumidifier revisit
Larry in NW Ohio
>The original port was getting a little far down, so I wanted to restart it. I don`t want to sound to stupid here, but I don`t recall hearing of a condensent pump. What, where, and how does it work? Thank You Larry In Ohio
Re: Basement shp/dehumidifier revisit
Re: Basement shp/dehumidifier revisit *LINK*
Dan Donaldson
>You can get them at the borg. It is the same pump that is used to drain the water from your air conditioner. Just a little box with an inlet and an outlet that has a float in it so that the pump runs when the built in container gets full.
Here is a link to see what they look like. You can probably get one cheaper than here.
Condensate pumps
Like a mini sump-pump
>If your HVAC or dehumidifier is above ground level you can use a hose and let gravity drain it. If it's in the basement and needs to drain up, it will pump it up for you.
Happy Woodworking!
