ADVERTISE HERE - FREE TRIAL
Homemade Air Filtration System
John Tom
>After all the years doing woodwork,I have finally decided to fight that dirty four letter "DUST". Can anyone lead me in the right direction for some plans on how to make one. At least enough to lead me in the right direction.
Re: Homemade Air Filtration System
Squirrel fan, plywood, lots of filters *LINK*
>They are pretty easy to make, I've made a couple. I'm not sure how important plans are since you will built it to fit the fan and filters you can get.
So here' the recipe:
One Squirrel cage fan with 120V multi-speed motor.
Get these from an HVAC installer. I usually pay between $5 - $10 for these. Don't bother with a 240V, stick to a 120V one. They will almost always have a 2-3 speed motor. Look for the direct drive ones where the motor sits INSIDE the cage, not outside with a belt. Size? Don't get one from a car heater, nor from a shpping center HVAC system. One fro a residentail furnace is fine. Outside measurements of the blower will be about 12"x14"x16" or something like that.
Plywood. Enough to make a 5 sided box. Size it to fit the squirrel cage blower with about 6"-12" around each side. Size it so that you can fit standard sized air filters in the open side.
Filters. Find a standard size. Something like 16"x20" or 20"x20" or whatever seems readily available at your local store. Buy several. The first one (or two) can be those 50 cents ones, the next can be those $30 ones, the next can be a $6 one and then a $12 one. Idea being the first one catches the dust first, and will ahve be replaced more often. Use cheap ones to replace often saving the more expensive ones. Depending on you use, you might change the 50 cent one weekly, the $3 monthly, the $6 twwice a year and the $12 one yearly. Just an example of course.
Use a properly rated power switch to provide 2 or 3 speeds. Get a $9 timer if you like.
A little glue, a few screws, a littel wire and bingo, you've got an air cleaner.
I have some wiring/switch hints on my website: www.happywoodworking.com
Happy Woodworking!
Norman (Ottawa, Ont.)
>Hi John,
If you are referring to a whole shop dust filtering system,
this idea might do the trick for you. It filters the air
in the shop over a short period of time.
http://www.fineboxes.com/DowndraftTable.htm
Norman
Outrageous!
Neal in San Jose
>I got my blower for free. I happened to see an HVAC company's truck down the street, walked over and saw that there were two or three blowers in the back. The technician walked out about that time, so I asked him if I could buy one. He said no, but that I could have them all for free. I only wanted one, so I took the smallest one (they were all larger than I really wanted). I looked it up in an HVAC catalogue later and discovered it will move something like 1800 cfm at 1 inch of water. That's a lot of air!
I buy bag filters from a commercial HVAC shop that measure 12 x 24, and are rated for clean rooms (don't remember the exact rating, but they are very good). You could buy the filters from Jet or Delta or anyone else that makes the commercial units; just use two side by side. I put a couple of "roughing" filters in front of the bag to catch the big butterflys and small cats so it lasts longer since it is the most expensive part of this rig ($35 or so the last time I bought one).
I recommend that you put this thing on the floor, or as low in your shop as you can get it. Dust is heavier than air, and will tend to settle, so catch it where it will naturaly go, and don't pull it up thru your breathing zone.
Mike de
>Tom,
I built one that works very well
You can check it out in the Shop Shots
http://www.woodcentral.com/shots/shot522.shtml
Re: Homemade Air Filtration System *LINK*
Mike de
>Tom,
Jim Dillon
>John,
I built the between-the-rafters air-cleaning system described in Wood magazine, #120, 1999, pg 70-73. It works very well.
American Woodworker magazine, #80, 2000, pg 42-47 describes building between-the-rafters, hanging, and benchtop units.
Following the opinions of many, I went to three HVAC contractors looking for an old blower motor assembly. At all three, I was looked at like I was from Mars, and rhetorically asked why would they keep old motors around when they had enough junk already. I took that response as a "no" 8-). I ordered a new one from Grainger.
The air-scrubbers really do make a difference IMO; I have mine right over where I sand. Good luck.
Jim
Bartee (metro Atlanta)
>Like has been said, a 5 sided plywood box, sized to fit 12x24 filters.
I used a fan from surpluscenter.com. They are not listing the fan I got and don't seem to have any that are large enough right now. I also ordered a 1 micron filter from Penn State industries.
The best filters seem to be the good 3M filters. I use two of those in front of the 1 micron. The 1st filter seems to do the job.
This does capture dust, since I have to change the 1st filter layer frequently.
I don't have any pictures of the construction, I will try to get some this weekend, if anyone is interested.
Here are a couple of PICs of my unit.
Re: Outrageous!
Ray - SW Ohio
>You are right about placement of the filter. Having it down low has helped keep the dust down on the tools. I have mine low too. Why would anyone want to pull that dust up into the air?! My 2�.
Re: Outrageous!
albertabob
>That's a good point about trying to catch the dust at the source, which brings me to my suggestion:
With these furnace blowers so plentiful why not consider making a downdraft table?
If you could build it level with your tablesaw so it could service as an outfeed table when not collecting dust.
There are a couple of decent plans floating around on the net.
Bob
