HVLP Sprayer
HVLP Sprayer
HVLP Sprayer
joey basile
>1. I need to paint a built-in I'm working on. I'm looking at a 4 stage Fuji, or a Wagner HVLP conversion gun. My compressor is only 2hp though, that's why I'm leaning toward the Fuji. Anyone else had to resolve the same problem?
2. I have done a dry fit and I'm wondering if I shouldn't paint everything flat, to lessen the chance of dripping?
3. I've seen pictures of simple spray booths, but can't remember where. Can anyone point me in the right direction?
Thanks Joey
Re: HVLP Sprayer
Binks Mach 1
Kirk D.
Re: HVLP Sprayer
Re: HVLP Sprayer *LINK*
Jim Dillon
>Joey,
Regarding spray booths, Michael Dresdner has a nice description of both bench-top and free-standing home-made versions in his newest finishing book. Finishing books by Jeff Jewitt and Bob Flexner also contain discussions regarding spray booths, each with slightly different emphasis and focus.
If you are interested in Wagner spray guns used with a small compressor, this web page may be helpful (link below). I have and have used the Wagner gun described in this link, and am getting ready to spray a lot of shutters; I've been satisfied with it - so far - using a 1 1/2 hp hot-dog compressor. Jeff Jewitt's web site (www.homesteadfinishing.com) offers a wealth of info and quality spray guns and supplies. Good luck.
Jim
Wagner HVLP Conversion Gun
Re: HVLP Sprayer
Addendum
Jim Dillon
>Joey,
I just remembered something important that someone pointed out to me here at WoodCentral regarding small compressors; they pick up moisture in the tank(s) and transfer that moisture to your finish. This is much more likely to occur with smaller compressors because they have to run a lot more to keep up with spraying, especially if you are spraying larger objects. A solution is to use a disposable drying cartridge next to your spray gun and/or a more permanent setup near your compressor. I believe Homestead Finishing sells drying setups. This is on my list of things to do this year. Of coarse, it was on my list last year too 8-).
Jim
Re: HVLP Sprayer
JackLane
>Hi Joey
I have the Fuji Q4 and someone in our shop sprays with it every day (I own a cabinet shop). We've been making do with the Q4 and several extra cups for over two years. We're spraying enough now that we really need a pressure pot or preferably a AAA rig. My main finisher keeps making it happen with the Fuji so other tools end up taking higher priority.
IMO, you won't find a better turbine outfit. Also, Fuji's customer service is fantastic. The gun comes with a gold 1.4 mm tip and air cap set. This is great for heavier bodied lacquers,latex paints etc. If you like to shoot water based lacquers or things like Minwax Polyacrylic (which sprays great BTW even though they don't recommend it)you'll want to drop back to the 1 mm blue tip.
Any time you can spray flat, spray flat.
I found this little video earlier today. I think it's great and very well done. He shows how to make a slick knock-down spray booth. Michael Dresdner used to hang out here on Woodcentral. Not sure if he still does.
Good luck
Jack
Michael Dresdner
