A55 Smoothing Plane
When and why did a 2x4 become a 1 1/2 x 3 1/2?
Steve Silca
>My guess is in the 1930's and because they basically realized that 1 1/2 x 3 1/2 was enough support for wall studs.
Re: When and why did a 2x4 become a 1 1/2 x 3 1/2?
Gary Camp - Bend, Oregon
>When I was a kid, my dad taught me that 2 x 4's were 1-5/8" X 3-5/8". I'm thinking the change over came in the late 50's to mid 60's. I don't really remember the sizes when I was a teenager, but by the time I got out of the Navy in 71 the change had been made. Why, again this is a guess. Better saw technology allowed for less waste, combine that with narrowing up a two-by by an 1/8" in each direction, you might be saving up to a 1/4" each way. Over the course of a day that could add up to several more 2 x 4's per tree. Not that this reason had anything to do with it but, the measuring is easier too
glc
Dale Lenz
Garys close, with the time frame. *LINK*
Dale Lenz
>Scroll down in the link below to 1970
1970
>As it dried.
Original rough-cut stock was 2x4, then it's dried and shrinks, then it's surfaced "smooth" on 4 sides which takes more dimension mostly leading to being able to get consistent 1-5/8 x 3-5/8 but calling it "2x4" because that how the tree was originally cut. Then politics and cost-cutting jumped in about 40 years ago with smaller trees being harvested and the "they'll-never-miss-an-eighth" thinking prevailed. So maybe they get 2 or three 2-by out of the log and "2 by" is just a name.
So, like, youz want fries with that?
What a great link!
nailshooter
>Been in construction for over thirty years and never knew some of that stuff. Had no idea the gang nail was invented in the 50's.
Thanks!
Robert
>The Standards people may have voted for the change in 1970, but when I got out of college in 1971 we were still struggling with the change. We were building commercial buildings and had to be careful that all the shipments were made to the same standard. Probably by 72 it was all the smaller stuff.
Two by Fours went from 1 5/8 by 3 5/8 to 1 1/2 by 3 1/2. 2 x 6's dropped from 1 5/8 X 5 5/8 to 1 1/2 X 5 1/2. Larger pieces lost more. 2 x 8's dropped to 7 1/4 from 7 5/8. 10's and 12's did the same.
Here's what I always thought.
Basil
>I did carpentry work (framing to finish) back in the 60's. We used locally grown and processed SYP mostly but some from out west and Canada. The imported stuff was always kiln dried. The local stuff was usually so green that when you hit that last lick with the hammer, splash, you got sap in your eyes. We used to joke about the sawmill must have just run the squirrels out of them the day before. A lot of times that was true.
Back then rough cut was 2"x4" or there abouts on the old circular sawmills. If it was local green stuff and planed (usually was), it was 1 5/8" x 3 5/8". The imported kiln dried stuff (usually studs for the walls) was 1 1/2" x 3 1/2". Now when the top plate and shoe of the wall is 3 5/8" and the stud is 3 1/2", you have a slight problem but manageable.
Now here was my thinking back then. The green stuff was planed to 1 5/8" x 3 5/8" because when it air dried it was a close match to the measurements of the kiln dried stuff.
And how many of you have taken those stupid multiple choice test for a job that always seemed to have this question:
What are the correct dimensions of a 2x4.
A. 2"x4"
B. 1 5/8" x 3 5/8"
C. 1 1/2" x 3 1/2"
D. None of the above.
I always circled that one and wrote on the test "All of the above".....LOL
Being a smart A$$ may have cost me a job or two......LOL
Binen
>Not sure when they changed but the reason for the chage is profit. Why make 3 studs to sell when you can make 4 studs from the same amout of raw material. Too bad the gas companies can't figure out a way to charge us for a gallon of gas but pump just 3 quarts. Maybe that is how we could get the price per gallon of gas down.
Binen
Test
>Define: EIGHT-FOOT 2X4
Answer: A favorite framing member used in vast quantities by handyman-remodeling contractors with the word �Doctor� in their business name. Most commonly of spruce wood cut in cross-section measured at 1-7/16" by 3-7/16", when installed in the prized �wet/green� state, they are unsurpassed for producing the ever-popular �undulating wall� effect that is enhanced with proper slow aging, and are economical in use because they only require a single toenail at top and bottom.
They already do that
>The sell gas by the liter in Canada.
And it works. Gas is much cheaper in Canada because it a $1 for a whole liter compared to the US where you pay $3 for only a gallon.
Happy Woodworking!
Re: Garys close, with the time frame.
Chuck Lenz
>Jack Schmitt invented the 4x2 parallel chord truss, most commonly used as a floor truss ?
Jim Smith
>Hello, I don't know when but pretty sure it was Weyerhaeuser that started the change for the reason several people have already stated, Profit, could get more lumber out of log. Weyerhaeuser was a great company to work for when run by family members, but present CEO is destroying it piece by piece.
The gas companies did cheat you
Charles R. Smith from Victoria
>Yep, the gas companies did get you. The gallon in Britain and Canada is 40 ounces. But it's only 32 in the U.S. You got cheated out of a fifth of a gallon.
So when comparing fuel mileage between Canada and the U.S., it was always necessary to convert the differences between gallon types. Of course, now it's all metric here.
Charles in Victoria (who still thinks in miles per gallon)
Huh? *LINK*
Jason Roehl in Mulberry, IN
>40 ounces to a GALLON? That would be SMALLER than ours--which contains 128 ounces.
You said 'gallon', but I what I think you meant was 'imperial quart'.
There's a pretty interesting article on Wikipedia about the different weight systems Britain has used since the Imperial system was codified in 1824.
Jason
Wikipedia Imperial Unit
Re: They did it with liqour
Al Stokka - Cambridge, Iowa
>A fifth (4/5 quart, 757.0824 ml) is now 750 ml.
let's not act surprised
Tom Sontag - St. Louis
>Of course manufacturers raise prices by means other than changing how much they charge. Candy bar manufacturers constantly reduce the size of the bar so the price looks the same in the vending machine. This happens with almost any packaged good: detergent, chips, liquor.
Not to veer too far into political realms, consider this: throughout most economic history, periods of inflation were offset by (painful) periods of deflation, so the purchasing power of a dollar or pound stayed relatively constant for centuries. Since 1913, the power of a dollar has declined something like 95%. Get ready to buy your booze by the ounce.
Re: let's not act surprised
>Okay, so the power of a dollar has declined by 95% since 1913, but what has happened to per capita income in the same time? I KNOW they weren't making an average of $45,000/year or so. Heck, that's double what I remember reading 25 years ago (in elementary school...)
Jason
Quick comparison...
John in New Mexico
>Look at the price of an ounce of gold relative to wages or whatever you're interested in. You'll notice everything cost a lot less when gold was $20/ounce.
John
Re: Quick comparison...
Rod Peterson -- Ormond Beach
>I don't mean to be argumentative, but when was gold $20/oz? In my lifetime (1946), the lowest it's ever been (in the U.S.) was the $35/oz which it had been fixed at since the '30s. I don't remember when it was allowed to float, but Nixon seems to come to mind. Since then it's been hundreds of $/oz.
For further comparison of wages and buying power, when I hired on in the FAA in 1968, I was a GS-6 at $6,137/pa. The journeyman level was GS-12 at about $12K/pa. Gas cost roughly 27�/gal, and I think I paid around $100/month for my first apartment. I bought a 2400 ft2 house in 1971 for $38,500. My new 1972 Olds Cutlass cost me around $7K and I thought I left a lot of money on the table.
My last car cost me almost five times what the Cutlass did, and my house today (similar square footage as the first one) is worth probably seven or eight times as much as the first one. I don't even want to talk about gas, as it's more than ten times what it was back then.
I guess I should have dumped my GM and FNMA stocks and bought Exxon…
Ah, the good old days…
Rod
John in New Mexico
>basically, back when there was still a $20 gold coin ;). But as you pointed out, the actual price/date is less important than the context. Gold is just a good rough benchmark since it emphasizes that the price increase we see in gas, cigarettes, houses, cars, etc, is mostly inflation. Of course, this isn't very scientific, just a kind of reality check on whats actually happening.
John
r payne
>They still aren't making and average of $45,000/year. That is the median which means half the population makes more and half makes less. The average (haven't checked for a couple of years) I think is around $30,000.
The real comparison that needs to be made is the cost of something versus how much is made. Prices have risen generally about 1.3 to 1.5 times wages.
ron
Re: Quick comparison...The big difference
Larry Clinton At Frankfort (Central)., Indiana
>is taxes & taxes and taxes. When I got my first industrial job in 1959, I made -as I recall - $82 something a week. I took home about $80 after ALL taxes were taken out. Social Security only taxed a fixed amount each year and it was paid up by spring or mid-year. There was no Indiana sales tax, state income tax, county option tax, etc. Car license fee's were around $10 (for any price vehicle). Gas was around $.20 / gal locally. Propane was $.159 a gallon. Real Estate taxes for our families modest home in Roselawn, IN was less than $20 / year. There were no Poll tax, wheel tax etc. in Indiana. Now we support a rather large portion of the US population (politicians of all parties and their staff) who contribute IMHO,
no benefit to most of us, via those taxes. The sliding scale and deductions for federal taxes was originally designed to pretty well exempt the working class, as income (inflation) occurred, we "donate" a much larger share of our income to the government. Don't mean this as a political argument as I feel all the parties share the same blame.
I know you don't like Wikipedia, but... *LINK*
>There's a chart somewhere down in the article I linked below about the relative buying power of a dollar. The chart sets 1980 at the $1 mark and compares a bunch of census years before and after. 2006 comes in at $2.45, 1910 comes in at $0.11 and 1920 shows $0.24.
1933 saw the dollar tied to gold at $35/troy ounce.
1975 was when the dollar went off the gold standard, so you were close on the Nixon count. (Wow, something HISTORICAL in MY lifetime...barely!)
Jason
http://en.wikipedia.org/wiki/United_States_dollar
Re: overbuilding
>I think the amount of wood being wasted when building a house is a crying shame. A lot of people nowadays want 10 or 12 foot ceilings too, and if the house is less than 3000 square feet, it must be a for a poor person. My wife's grandfather bought 2x4's to build a house then cut them in half for the wall framing, so the studs are 2x2; the house is still standing I think, 60 or whatever years later. A small 2 story house. We will not be able to rape and pillage our natural resources forever.
Steve Schoene
>Actually, the mean family income is substantially more than the median. According to census bureau data, in 2005 median family income was $56,194, while the mean (arithmetic average)family income on the same basis was $73,304, which is 30% higher than the median. This reflects the fact that at the high end of the scale incomes rise more rapidly than the population.
For comparison, in 1953, the earliest year in the particular data series, median family income was $4,242 which was $26,275 in 2005 dollars. Mean was $4,706 which was only 11% higher than the median.
The difference is one measure of the fact that the rich are relatively richer compared to the typical family now as compared to the flatter income distribution in 1953.
There are lots of ways to measure incomes, some of which yield different numbers because different things are counted so it is important not to compare apples to oranges by picking data from one series to set aside data from another.
