Another house painting question OT
>I posted a couple of days ago about painting the interior of a rental house. Thanks to all of you who answered.
Since the inside was very colorful and shiny, thanks to the previous tenant, and very dirty (can you say squalor?) I reluctantly decided I needed to both clean and prime.
I used TSP to clean the trim and some of the nastier places on the walls. Amazing what it took off.
I realized the old existing paint was not adhering to some of the trim, so I sanded it as best I could. Found that where the trim had been dirty before the tenant painted it, the top coat came right off. Spent several hours scraping and sanding.
On advice from two paint stores and here at WC, I bought Zinszer 1 2 3 as primer. I read the label and it says to clean as necessary with the appropriate solvent, (NOT TSP.)
No explanation of why not to use TSP. Everyone I talked to said TSP was great stuff and left no residue. Now I am at a loss. The guys in the paint store were remarkably unhelpful. The guy at Lowes was more forthcoming, but I'm not sure he really knows his stuff.
I have put the 123 on the walls, but not yet on the trim I have washed. Should I buy a different product of the trim or just go ahead with the 123?
Re: Another house painting question OT
Larry in NW Ohio
>Barry Call the company, should be phone # on can, and ask them why. Larry in Ohio
Re: About TSP...
Glenn Madsen near San Francisco
>I'm a Californian. For some time now, we can't buy TSP, real TSP. Something about polluting the rivers, killing all the wildlife, messing with the foodchain. Or something like that. You can believe everything you hear from the activists, right?
You do need to clean that trim. Simple Green was mentioned. Works really well. Rinse it, too. Then prime. And sand a bit, too. And wipe it down.
If this were my home, I'd be tempted to order up some new trim, and go way overboard. I do that at times.
On my dad's place, about 2 years ago, we did all of this. Some of the paint still peeled. Stuff happens. We may fix it later, but for now, it's in the guest room that gets used about three weeks a year. In some rentals, paint gets slapped on, because there is so little time for prepping it correctly. And prepping it correctly is 75% or more of the success of a paint job.
Jim Dillon
>Barry,
Just guessing here, but Glenn probably is close to what is going on. There is indeed an issue with phosphates and pollution and TSP may be available on a state-by-state basis.. So maybe that is why Zinsser is mute on the issue. I've never heard of a problem with TSP (as a cleaner) as long as it is rinsed well and the surface is allowed to thoroughly dry. Might be worth a call to Zinsser. My less than 2 cents worth.
Jim
Kirk D.
>Hi Barry,
I use TSP to clean things often. In my town the hardware store only sells phosphate free TSP. I wonder if this would work for you? The best move you could make is calling the paint companies tech line. I hope you let us know the outcome of your research.
John Veerkamp
>Phosphate free TSP is NOT Tri-Sodium Phosphate. TSP is used routinely by restorers and insirance company repair folks. If it is rinsed off there is ni problem with paint adhering.
John
Kirk D.
>Hi John,
I disagree with your last statement. I was trying to help Barry with his question. I have used TSP often. I have noticed over the last several years TSP was replaced on the shelves by TSP-PF. It seems to clean just as well as the original TSP. Both products made by the same company. I stand by my original statement and intent to help Barry. Also Barry please inform us of any info you found about them not wanting you to use TSP.
