Isn't that how it's SUPPOSED to be done??
>In kitchens at least.
All the kitchen outlets in my current house (Atlanta) and my previous house (Toronto) have two completely different circuits in each outlet. The top half and the botton half are on different circuits and are fed by two seperate cables.
Yes, that means if the circuit is tripped in the upper outlet the lower outlet is still live, so you wouldn't want to be replacing the outlet with only one circuit breaker turned off. Did I mention that's HOW i discovered that there are two circuits in each outlet? Ouch!
I thought that was the way it was supposed to be done (according to code and/or city regularions) when it comes to kitchen outlets. So that if you blow the circuit with the mixer, you can continue making the cake without heading to the garage to reset the breaker. I guess it's really so you can have the toaster and mixer plugged in to the same outlet box and run at the same time.
If it's a requirement for kitchens then I can't see why it wouldn't be allowed elsewhere in the house.
Of course I'm not an electrician, but can help stir up the pot here just as well as anyone ;)
Happy Woodworking!
