What material?
What material?
What material?
Eric Murphy - Spring TX
>Let me start off by saying I first started posting design questions about this project last year and am just now finally making some headway on it.
I am working on a "Greene & Greene inspired" stereo cabinet of my own design. I took some of the common Greene & Greene elements and incorporated them into my design.
This photo is of one side of the cabinet showing the ebony "tsuba" and "Blacker brackets". Note the holes visible in the "tsuba". I'll come back to them in a moment...(to be continued)
Re: What material?
Re: What material?
>This photo is of a chair from the Gamble House showing the ebony tsuba shape. Note the (what I assume to be) brass pins/nails around the edges of the tsuba.
Now, back to the holes in my piece of ebony. What I planned was to emulate the look of the brass pins seen in the chair photo. I have a couple of small chunks of osage orange that would fit the bill nicely in terms of color and "looking like" the brass pins. However, what concerns me about using a wood plug is when I sand, I want to get the true color of the wooden plugs, not the plugs stained by the black ebony dust created from sanding.
I've thought about the possibility of using something like a thin sheet of plastic with a hole so it fits over the plug and I'd only be sanding the plug, not the surrounding ebony. I've also wondered about using something other than the osage orange such as brass rod but then I see the issue as being getting a nice polished end on the visible end. Or, I also noticed that Penn State has yellow colored stabilized box elder burl pen blanks in their catalog. I don't know whether the stuff they use to stabilize would prevent the ebony dust from discoloring the yellow or not.
I would appreciate any suggestions that anyone could offer on how to achieve the look I'm going for while avoiding the issue with staining the plugs with ebony dust.
On other notes, I'm not particularly happy with the hole pattern I drilled in the ebony but the ebony is too expensive to start from scratch. I've come to live with it and accept it the way that it is. Also, the reason for the tape in the first photo is to mark each of the joints and the locations to drill for the square ebony plugs later on in the process.
Re: What material?
Don't sand that area...use a cabinet scraper
Lee Brubaker
Re: What material?
Re: What material?
jcousins
>i did a clock out of black walnut and used brass brazing rod for the hour indicators on the face. seemed to work well - soft enough to sand and did not discolor from the walnut - although i know that the ebony dust is finer. but - the osage orange will not stay a light color - it really changes much darker.
jerry
Re: What material?
The Osage (Bois D'Arc) will change
Phil Joines Krum, Tx
>to a milk chocolate color as it ages. No way to stop it. Use brass. Polish them first and install them after the finishing is complete.
Re: What material?
One shop I know...
John in New Mexico
>that does a lot of G&G stuff uses copper pins. No idea if thats what the originals use. They'd oxidize quicker than brass though, and whatever is in the photo looks oxidized.
John
Re: What material?
Re: What material?
Tom Stockton
>Eric,
I'm fairly fond of sterling silver wire and use it in some of my Greene & Greene pieces. It works well, I file it flush and then sand it.
Tom
Re: What material?
WOW !! I LOVE IT !!
Mark Valsi
>Man, Eric, that is looking great so far. Keep us posted and keep posting pics !!
I love those blacker brackets out of ebony !! WOOOOOWWWWWW !!!
Re: What material?
Why substitute?
>Instead of emulating brass why not use brass? Just purchase a lentgh of brass rod and cut a series of pins.
You already have a lot invested in good materials there (and it's looking good by the way) so why cut corners with the pins?
Tom
Re: What material?
Thanks all and question for Tom Stockton
>Thanks for the responses everyone. My main concern with just using brass was whether I could get a nice polished surface out of it. Just to clarify, I'm not so worried about whether it is all nice and shiny, I just don't want to see the scratches from filing/sanding, etc. I will pick up some brass rod and try it out on some scrap material and see if I can get it looking like I want it.
Tom, I like the way that sterling wire looks too. Any hints on where I should look for it? What types of stores would have it? Also, I think the holes I drilled are 1/4 holes. Is the sterling wire available that large?
Thanks again all!
Re: What material?
Re: Thanks all and question for Tom Stockton
>With using very fine grit wet/dry sandpaper you should be able to get a polished surface on brass. If you have some honing paste that would get a good final polish on it as well.
Tom
Re: What material?
Re: Thanks all and question for Tom Stockton *LINK*
Tom Stockton
>Eric
What Tom Skaggs said about polishing brass is pretty much what I do, brass is a little harder than sterling silver so takes more time but not much. I find good results stopping at 320 grit.
Some jewelry supply places carry wire,bead stores and lapidary supply places also have it. I order it off the internet from the link below.
Tom
http://www.ccsilver.com
Re: What material?
>I see brass rod for sale at the local hardware store. Often times with the hobby stuff, like balsa wood etc.
Tom
