Router bit storage question...
>I am building cabinets for my shop. I've accumulated a number of router bits over the years. Some are keepers, others are not. I figure on getting rid of the "cases" that some of them are kept it. I've seen the somewhat pricy brass inserts in the Lee Valley catalog as well as the inexpensive "advanced polymer" ones that you can screw into a backing board. I've also seen the interlocking bit trays that Klingspor catalog has to offer.
The LOML said "why can't you just drill holes in a block of wood?".
The Lee Valley catalog (and website) says: "One advantage of using these holders for bit storage, rather than simply boring suitably sized holes in a block of wood, is that they act as barriers against wood moisture migration, protecting bit shanks from corrosion." for their brass inserts and I presume that their plastic ones offer similar protection.
So - truth or exaggeration? How about blocks of wood? How about the Klingspor plastic blocks? What do you use to store your bits?
