New router table
John D. Luke
>Wanted to share with you all my new router table I'm in the process of finishing.
It started out as a Rockwell over-arm router I got off of ebay several years ago. I got it pretty cheap since it was missing the original cast iron top and was replaced with cheesy particle board sink cut out piece.
I already had the sheet of 1" thick micarta that I had picked up from Boeing surplus and was hoarding for a future project.
Mounted the micarta to the over-arm and used this way for several years.
Recently I bought a second shaper for the shop and it was getting crowded in here, and I wanted to also get another router table to replace the old one that was starting to get beat up.
I than had an inspiration to combine the router table and over-arm router into one unit and trash the old router table and place the new shaper where the over-arm router used to be.
Got the Rockler large aluminum router plate and mounted it into the table, (lots of fun routing through 1" thick micarta)
The plate is mounted into the routed recess and I drilled and tapped 1/4-20 holes at each corner and screwed in 1/4-20 brass bolts for plate leveling.
The over-arm router fence is an old Delta small shaper fence mounted with 5/16 studs threaded into the micarta top.
The under table fence is a Jessem Master fence and the mounting rails are secured with 10-32 screws threaded into bottom of table top.
The white box on the lower left is a 220v contactor for the over-arm and next to it is a 110v switch for under table router and shop vac.
I have to use this for a while now to figure out where I want to attach a power feeder for the under table router. (I build a lot of tables and it works a lot better with a feeder to rout the edges of a 40" long sofa table)
This photo shows set up for over-arm routing
Questions and comments appreciated.
