>I am building a playset out of Douglas Fir and Cedar. I was told by many that the fir will hold if I maintain it year after year. I did not want to use pressure treated lumber as i simply don't like much about it. I was looking into yellow pine but everywhere here had to order it and it was outrageous in price. Anyone know what kind of tinted sealer would be best to put on the fir and cedar? Keep in mind there will be kids all over this thing so I am trying to stick to something not so harsh. Any suggestions are welcome.
>For the last nine years or so I have been using a Cabot stain on a cedar deck that I have. If it was a Playset that I had here that is what I would use. Pick one with some pigment since the pigment is what you want for life of the stain.
>I would definitely not use CCA lumber. It is nasty stuff. Your best bet to keep safe with it is to apply an oil stain yearly. I have seen scientific studies showing that even after applying a good oil finish that the arsenic still leeches like it never was coated after only 6 months. I simply don't want to put my youngin' in harms way when I know to much about it.
>There is a lot of conflicting information out there as to pressure treated lumber & arsenic leaching out of the lumber. The City here has a lot of playgrounds with pressure treated lumber & of course became concerned. They had the local university test for arsenic leaching at well over 50 playground sites & found NO measureable leaching. HOWEVER being of a suspicious nature especially when considering the cost of replacing over 50 playground sets I kinda wonder about the findings. Anyway, why take the chance when there are other alternatives.
Here is a link to an enviromentally friendly preservative (or so the advertising says 8-)). It is however NOT a stain. You can also check out the MSDS for the product; it's interesting and FWIW the finish is used by the Park Service in Canada. While I have never used this specific product, I have used other preservatives/stains from the company (Schroeders Log Home Supply) on a log home. They offer good service and a wide selection. You can browse their other finishes etc. in their online catalog. Conventional preservatives/stains like Cabots and Sikkens seem to work fine but I can't speak about their toxicity. And until things get sorted out on the new preserved wood, I would stick with other woods. Cedar is a good option, but around here it is VERY expensive especially for clear wood. Cypress might work also. And your suggestion of a well-constructed playset made from fir might be the least expensive and last (with some maintenance) long enough. Just some thoughts.
>I am going to place a 10"sq. piece of composite decking under all 6 posts to keep the thing from direct ground contact. Its a fairly large playset, dual platforms 5'x5' and one 4'x5' one at 5' the other 4' with a 12-14' swing beam 7-8' high coming off the top of the 4'platform. Its looking pretty darn sweet as its coming along. Neighbors even comment how nice it is going to be. I am using composite decking for the 2 platforms. I couldn't help but hook the slide up last night and let the 2 year old go ripping down it. He hit the first hill in the center of the slide, took some air, slid the rest of the way down on one butt cheek flew right off the thing onto the lawn right on his butt....thought he might cry but instead got up and did what resembled a victory dance. Gotta love seeing the rewards of your hardwork. I will look into your suggestions, mighty glad for the feedback.
