I want a tool that does this....
Alan Young
Alan Young
>I am looking for a small hand held tool for flattening the ground around carved elements. I can't find a tool that is shaped the way I want. Ideally this tool would have a 1/4 inch serrated surface like a file but it would be at the end of a curved or bent handle.
I have a variety of smile rifling files but the bent angles are acute enough.If anyone knows who makes or sells something like this I'd be happy to know more. Thanks.
(I am posting this on the Hand Tools and Carving Boards also)
Alan
Re: I want a tool that does this....
Ernie Miller
>Why don't you make it? I have had to make several of my carving tools that are kind of special. I would use a 6" square cut nail aneel it. get it cherry red hot place it in some ash or vermiculite to cool as slow as possable come back the next day bend the nail to 90� or what ever angle you want 85� would probably work better grind or file the nail head flat might be easier if you do that befor bending. then file in a series of teeth like you are making a plane float in this case you may want 4 rows of teeth cuttin in each direction or you may need to make two tools one that cuts on the pull and one for the push. I doubt that you will need to reharden the nail as floats and saws are made of a slightlu softer metal. Turn or carve your self a handle drill a hole slightly smakker than the nail point and burn it in like you would any other chisel handle. Pretty quick and simple project. Bet you could do it in less than a hour over a couple days. I think the head on a 6" nail is about 5/8X3/4 or so if that is to small you may want to go with a smaller nail. Stop by the hand tools if you have questions about floats. simple tools to make
Or have it made....
>Guys like Dave Thompson (Turning Forum) can make custom tools like that for you.
Happy Woodworking!
Or have it made (correction).....
>Oooopss... brain isn't in gear. I meant:
Guys like Doug Thompson (Turning Forum) can make custom tools like that for you.
Happy Woodworking!
Robin Corell in Atascadero CA
>The traditional tool for doing what you describe is called a fluteroni or a macaroni, though a standard bevel edge chisel held with the bevel down does a good enough job for me.
Another traditional aproach is to use carving tools that have been used up so that litle more than the shank is left and then grind them into special litle scrapers. spoon bent gouges will have a bit of the bend left in their shank and make especialy nice scrapers.
There is also a japanese tool used to clean up the bottoms of mortices and these also make nice scrapers for carving as do japanese spear planes.
now to hijack your post a bit. With all the router carvers and cnc carvers on the market I really like to make my work look more hand tooled and tend to leave or even add areas of hand tooled texture with a large shallow gouge. I like the look of a rippled background and I think in most cases it makes the carving realy pop. it can be mostly smooth but the hundreds of tiny facets left by a gouge reflect the light and really make the surface come to life. This is actually one of the design elliments that has become part of my style and is smething that appears on a lot of my work.
Robin Corell
Henry (Raleigh NC)
>Alan: That looks an awful lot like (parts of) a hammer with a serrated face. I just looked at them recently, wondering why you might want a serrated face on the head of a hammer. Specifically, this was an Estwing framing hammer - 20 or 22 oz.
If you did not want to try making one, for the cost of ruining an otherwise good hammer you could cut off the claws to create a flat backside, grind the head square. You'd have something that would reasonably resemble your picture. The weight of such a tool may not be appropriate, but that's the way I'd try first if I were to want to make this. I don't have access to metal fabrication tools, but I could likely find a metal band saw and grinder to use.
Henry
Look at gunstock checkering tools.
Ray Thompson - Middletown,IN
>If you are trying to work small areas there are some checkering tools that may fill the bill.
Ray
Curly Smith
>Get one of these: Spice Grater
then either bend to suit or cut off a small piece and epoxy to an appropriately offset tool.
This microplane is 7/16" wide so it might just do what you need with a minor bit of work.
>Good Afternon Allan,
I bought something similar a few years ago to clean out debris left on spline grooves for sheet cane. The tool has a flattened hook rather than a checked foot below the curve. You might see what is available in caning supply houses.
George
Lee Grindinger
Why wait for a short shank?
Lee Grindinger
>Robin's got it, Alan. I have two dedicated tools for smoothing grounds, a 1/4" #3, and a 3/8" # 3. Used nearly vertically they behave like a scraper and make short work of grounds. The steel used in carving tools is too hard to roll a burr as you would with a scraper but dragging a shallow gouge vertically across a stone will make it a sweet scraper.
Frankly, I'll often just use the shallow gouge in my hand for quick touches not even reaching for the dedicated gouges.
Lee
Alan Young
Poor Planning
Alan Young
>I have used the smaller gouges as scrapers and like the results. In this case I have glued up pieces and then attempted to carve and relieve the ground. The pieces glued together-knee blocks on legs for a table leave me fussing around for tools that can get the work done at a workable angle. In other words the leg gets in my way. So In this case I'm looking for a bent tool. And one with a narrow ie 1/4" or less width to clean out spaces. I will "file" all these suggestions in my "OK, I get it, wait till next time" approach.
Alan
Larry Marker in Alabama
>Leather crafters use a lot of tools like that (they are straight like a punch).
Tandy Leather carries a lot of embossing tools that would do the job.
Larry
